Hello guys, i'm planning to make a belt sander with this high speed motor (5500 rpm) and my question is, Can i use this motor for the belt sander?
Thank you for your reply.
These people have a explainer on calculating the appropriate speed for a belt grinder belt: https://www.redlabelabrasives.com/bl...a-belt-grinder
I suspect 5500 RPM is quite a bit too high for direct drive, you might need to add a speed reducing pulley set between the motor and belt driving wheels to bring it down in speed.
Thank you very much
Hi The motor looks like a gear up to the posted speed ....I find 3600 rpm motor speed is best for me.. remove the gear drive and see if you have enough torque....If you want to grind metal you need horse power so I am not sure this motor is right for your application... hope this helps.
I use 4,000 FPM +/- 1,000 FPM depending on variables (i.e., material, grit, abrasive binder, etc). Equally important is 1 hp per inch of belt width. (i.e., 2" belt width = 2 hp). That is a professional value and you will never be disappointed. You will see lower horsepower numbers but you certainly don't hear the disappointment with all the 1/2 hp systems out there. 50 years ago the owner of Burr King (manufacturer of Industrial grinders) gave me that horsepower parameter and he was right!
Hi, i already did that and i found that it contain 2 pulleys and belts to increase speed and yes the motor has 2400 rpm with a 1.5 hp. And i think that this helps, thank you!
It seems like you have a good motor to start with. If you add a VFD, to dial in variable rpm, you will have a good solution for most materials. I have the chart below posted next to my machine. (FPM x .3048 = MPM)
All the best,
Belt Grinder SFM
Material FPM Acrylics 960 - 2700 Glass, Ceramics, & Stone 1560 - 2700 Lacquers & Varnishes 1560 - 2940 Hard & Hardened Steel 1560 - 2940 Plastic & Rubber 1920 - 3540 Titanium & Titanium Alloys 1920 - 4920 Wood 2940 - 4920 Aluminum & Zinc 3540 - 5880 Stainless, Tool Steel, & HS Steel 3540 - 5880 Copper & Brass 4920 - 6840 Cast Iron & Carbon Steel 4920 - 8820
Thank you very much!
