Results 1 to 7 of 7
Thread: Razor blade cryogenic tempering - GIF
    May 2024
    nova_robotics (May 27, 2025)
    Jul 2018
    Flora, MS
    Floradawg's Tools
    I didn't know that anyone still uses double edged blades.
    Sep 2018
    nova_robotics's Tools
    Applied Science did an amazing video on cryogenic heat treatment. For the life of me I cannot envision how improved material properties are achieved. It goes against everything I know about grain structure and heat treatment. Anyway, very cool nonetheless.
  5. The Following 2 Users Say Thank You to nova_robotics For This Useful Post:
    emu roo (May 28, 2025), Floradawg (May 28, 2025)
    PG1
    PG1 is offline
    May 2017
    PG1's Tools
    Cryogenic treatment is well documented in the literature
    [QUOTE=nova_robotics;251130]Applied Science did an amazing video on cryogenic heat treatment. For the life of me I cannot envision how improved material properties are achieved. It goes against everything I know about grain structure and heat treatment. Anyway, very cool nonetheless.
    The Youtube video description points to a couple of references that describe in detail what happens to the microstructure of HSS when cooled to liquid nitrogen temperature.
    The retained austenite (soft material) content is significantly reduced relative to quenching at room temperature only, and carbide precipitation is tripled. In addition, the carbide precipitates are reduced in size.
    Cryogenic treatment is expensive which is probably why it is not widely used,
    I wouldn't know about cold tempering, but I do know that steel can become very brittle in cold temperatures
    Lake Tahoe
    IntheGroove's Tools
    The Titanic...
  9. #7
    We had a contract to machine and fabricate some fixtures to be used in the Artic circle We had to provide coupons for Tensile, bend, notch, and cold saturation testing using several different brands and types of fillers and different heat settings on our welding machines. Just because a Filler manufacture provided Sharpie stats didn't always mean it would pass the -40° required test. I found 2 brands of .045 dual shield wire that would exceed the manufacture's spec sheet. the Hobart Excell 550 and Trimark 777.
