Results 1 to 9 of 9
Thread: Re-locatable vise handle
    Jyväskylä Finland
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tuomas's Tools
    I found my vise handle to be very annoying to use.
    Fixed it this way:
    Some time ago someone posted something similar.
    Didn't absolutely understand everything what was made, because of my ability to understand spoken English.
    So i made this in my way.
    But, thanks for the idea!
  2. The Following 16 Users Say Thank You to Tuomas For This Useful Post:
    Andyt (09-29-2020), baja (09-29-2020), benkeller3 (09-28-2020), Canyonman44 (09-28-2020), Chadboye (09-29-2020), DIYer (09-28-2020), high-side (10-01-2020), Jon (09-28-2020), Moby Duck (09-28-2020), oldpastit (10-07-2020), rebuilder1954 (09-29-2020), rgsparber (09-28-2020), Sleykin (10-02-2020), Tonyg (10-04-2020), Toolmaker51 (09-28-2020), Tule (09-29-2020)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Tuomas! We've added your Relocatable Vise Handle to our Vises category,
    Mentioned
    0 Post(s)
    Tagged
    5 Thread(s)
    You might be thinking of this one: Simple Bench Vise Mod by Retro Steam Tech.
    Yours is a nice development of that idea. Multiple positions, plus the full-circumference groove instead of a detent.
  5. The Following User Says Thank You to Jon For This Useful Post:
    Tuomas (10-03-2020)
    Jyväskylä Finland
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tuomas's Tools
    Yep it was that. I tried to search " self centering vise handle" but it seems that i remembered it wrong.
    ..Also this version can be locked to its position.
    Jyväskylä Finland
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tuomas's Tools
    Here is more info: https://www.instructables.com/Re-locatable-Vise-Handle/
    Grooves on the handle, are sharp edged.
    As is the head of the locking pin.
    This keeps handle locked to its place, until pin is released.
    Jyväskylä Finland
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tuomas's Tools
    New knob.
    Re-locatable vise handle-fb_img_1601652216629.jpgRe-locatable vise handle-fb_img_1601652222181.jpg
    Attached Thumbnails Attached Thumbnails Re-locatable vise handle-fb_img_1601652227366.jpg
  9. The Following 4 Users Say Thank You to Tuomas For This Useful Post:
    Jon (10-02-2020), sossol (10-02-2020), Toolmaker51 (10-04-2020), Tule (10-05-2020)
  10. #7
    Mentioned
    0 Post(s)
    Tagged
    5 Thread(s)
    Congratulations Tuomas - your Relocatable Vise Handle is the Homemade Tool of the Week!
    This is a significant upgrade on an idea from a previous winning tool, Retro Steam Tech's Vise Handle Modification, and was even upgraded again today. It will be interesting to see this idea progress; I wonder if one-handed adjustment is a feasible evolution.
    Rod Polishing Roller Support by Tuomas
    Center Punch by Crusty
    Lathe Coolant System by bouboulas
    Hydraulic Bearing Puller/Pusher Support by Tuomas
    Hand Truck by Kwandotechnic
    Hitch Pin Removal Tool by rgsparber
    Small Part Tethers by mklotz
    Drill Bit Sharpening Fixture by machining 4 all
    Measuring Tape Marking Attachment by orioncons36
    Short Circuit Protection Box by mariost
    Cross Table by warsztatOdZera
    Rotary Indexing Table by machining 4 all
    Multipurpose Chair by fawabros
    Lathe Cross Slide Backlash Fix by winkys workshop
    Storage Rack by tony b
    Cylinder Head Crane by KustomsbyKent
    Slot Routing Method by ananas studio diy
    Machinist's Vise by manshands
    CNC Joystick Controller by machining 4 all
    Lathe Feed PWM by machining 4 all
    Punch by ananas studio diy
    CNC by kwm24@o2.pl
    Hay Dolly Hook by Frank S
    Flexible Shaft Rotary Tool by HandmadeCreativeChannel
    CNC Router by Making Stuff
    Tuomas - you'll be receiving a $25 online gift card, in your choice of Amazon (US-only), PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 13th Homemade Tool of the Week win. Here are all of your Homemade Tool of the Week winning tools. Congrats again
  11. #8
    Jyväskylä Finland
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tuomas's Tools
    Thank you very much Jon.
  12. The Following User Says Thank You to Tuomas For This Useful Post:
    old_toolmaker (10-03-2020)
  13. #9
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No dispute a semi-fixed handle is worthwhile. Handle size partially determines whether friction or detent is needed, variables are in friction and area of contact. A detent can be 'tuned' also. Shallow is fine, trick is in shape of the plunger; whether contacting depth of groove or the edges, not both. When point touches, it locates easily with decent retention. When edges touch, that gets more positive. When both touch, contours cam out of place too easily. Another distinction is between ball or plunger detents; properly fitted, plungers have better alignment, where the sphere is forgiving.
    Anyway, clamping-wise once that is in place, the next best mod is loading the vise screw for near zero backlash. Take up thrust with short stiff coil spring and decent flat washers. The handle will stay in any clock position you need while jaws are open.
    Far easier than sprouting or grafting a third arm.
    Not to mention ensuing wardrobe issues.
    Post your reply!
    eBooks for Supporters
