Results 1 to 10 of 11
Thread: Recycling plastic bottles into brooms - GIF
Hybrid View
    Recycling plastic bottles into brooms.
    Recycling brake pads - GIF
    Recycling tin cans - GIF
    Recycling plastic into pellets - GIFs
    Plastic recycling machine - GIF
    Circuit board recycling GIF
  2. The Following 9 Users Say Thank You to Altair For This Useful Post:
    albertq (Aug 23, 2025), clydeman (Aug 23, 2025), cogentia (Jan 7, 2023), Inner (Jan 5, 2023), johncg (Jan 8, 2023), mwmkravchenko (Jan 6, 2023), nova_robotics (Jan 5, 2023), rlm98253 (Jan 5, 2023), uv8452 (Jan 8, 2023)
    neilbourjaily's Tools
    Set that up at the local farmers' market and sell a bunch of them.
    Sep 2018
    nova_robotics's Tools
    This is great. PET is an excellent plastic with some really great properties. Making some sort of filament and finding a use for it is a much better answer than plastic "recycling." I put recycling in quotes because basically everything we put into the recycling bin goes straight to trash. Almost none of it is actually recycled.
    Along those lines, a few companies have popped up that are using plastic as aggregate for asphalt. It's a good idea and improves the properties of the asphalt.
  5. The Following 7 Users Say Thank You to nova_robotics For This Useful Post:
    clydeman (Jan 5, 2023), emu roo (Aug 19, 2025), Inner (Jan 5, 2023), mwmkravchenko (Jan 6, 2023), Ralphxyz (Jan 6, 2023), rlm98253 (Jan 5, 2023), sossol (Jan 5, 2023)
    Supporting Member bob_3000's Avatar
    Aug 2020
    Sadly those brooms are microplastic factories...straw is the way of the future.
  7. The Following User Says Thank You to bob_3000 For This Useful Post:
    Saaglem's Avatar
    Oct 2018
    From South Africa, now New Zealand
    This is done in New Zealand for the past 5 years. Downer New Zealand has a plant that not just use plastic but also use shredded tires in the same process in our roads. This process is not yet used for our highways but is taken over in our cities.
    Cheers
  9. The Following User Says Thank You to Saaglem For This Useful Post:
    nova_robotics (Jan 7, 2023)
  10. #6
    Jul 2016
    Good recycling idea.
    Unfortunately adds to micro plastic pollution.
  11. The Following User Says Thank You to tooly For This Useful Post:
  12. #7
    hemmjo's Tools
    If they use plastic as the binder, then it is no longer an asphalt road.
  13. The Following User Says Thank You to hemmjo For This Useful Post:
  14. #8
    Sep 2018
    They still use asphalt. It's just asphalt as normal, but they add a tiny bit of plastic as aggregate. It's only a few percent plastic waste.
  15. The Following 2 Users Say Thank You to nova_robotics For This Useful Post:
    emu roo (Aug 19, 2025), Ralphxyz (Jan 6, 2023)
  16. #9
    Perth Ontario Canada
    Nothing has zero side effects. I am guessing the least egregious is the best choice.
    To replace the existing paving infrastructure would be an epic effort.
    Get rid of a lot of plastic. To a degree permanent sequestering.
    Mark
  17. The Following User Says Thank You to mwmkravchenko For This Useful Post:
  18. #10
    Dec 2016
    Ralphxyz's Tools
    I think nova_robotics, has the right idea. I don't believe they are replacing asphalt just using a plastic supplemented aggregate.
  19. The Following 2 Users Say Thank You to Ralphxyz For This Useful Post:
    emu roo (Aug 19, 2025), nova_robotics (Jan 6, 2023)
