https://youtu.be/hgEHC7kxg_g
Thanks Maisternia! We've added your Tire Inflator to our Air Compressors category,
as well as to your builder page: Maisternia's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-tire-inflator-6"> <img src="/uploads/260423/homemade-tire-inflator-6.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-tire-inflator-6">Tire Inflator</a> <span> by <a href="https://www.homemadetools.net/builder/Maisternia">Maisternia</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/air-compressor'>air compressor</a> </div> </div> </div> </div>
Those older compresses were good for that kind of thing. They are more forgiving of being operated outside their designed envelope. The newer models over heat too quickly with no refrigerant to cool them.
Only thing about the build I question is that filter in the discharge line. That is NOT made for the kind of pressures that compressor can pump. The inlet filter is a good idea. You are at risk for blowing up that discharge filter.
