Remove a broken tap
Remove a broken tap
Remove a broken tap from hole by drilling tap out with a masonry bit sharpened to form a spade drill
this will not damage the hole.
By placing guide plate on top to guide drill in location
this is a 1/4-20 HSS tap and a 3/16 masonry bit
Video link
https://youtu.be/rSShHH2Us5Q
Thanks shopandmath! We've added your Broken Tap Removal Method to our Tapping and Threading category,
as well as to your builder page: shopandmath's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-broken-tap-removal-method">
<img src="/uploads/229573/homemade-broken-tap-removal-method.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-broken-tap-removal-method">Broken Tap Removal Method</a>
<span> by <a href="https://www.homemadetools.net/builder/shopandmath">shopandmath</a></span>
</div>
<div class="tags">tags:
<a href='https://www.homemadetools.net/tag/tapping'>tapping</a>, <a href='https://www.homemadetools.net/tag/removal'>removal</a>, <a href='https://www.homemadetools.net/tag/repair'>repair</a> </div>
</div>
</div>
</div>
thank you much appreciated
Ray
I have melted the silver solder holding masonry drill tips in. I guess I should buy a metal spade insert to have on hand to copy the profile from.
Rob
