Results 1 to 6 of 6
Thread: Removing a ship propeller - GIF
    nova_robotics (Oct 10, 2022), Rangi (Oct 12, 2022)
    Lake Tahoe
    IntheGroove's Tools
    Now he can go African Queen on it...
    Feb 2015
    I SAID 'HIT IT HARDER!"
    May 2015
    Tasmania, Australia
    Bony's Tools
    It must be beyond repair to be removed so brutally, and the prop shaft was probably damaged too.
    hemmjo's Tools
    Would make a good video showing them banging that back into shape.
    May 2021
    Vancouver, Washington, USA
    In the 90's I worked in the shipyards in Portland, Oregon as an outside Machinist. I got to do a whole lot of of cargo and passenger cruise ship propeller removals and installs. Though, not quite Ike this guy is doing. We used cranes, chain falls, and porta-powers to CAREFULLY guide the wheel on and off of the shaft. Some ships used a special hydraulic nut to secure the prop to the shaft. The nut went on to a certain point and then a porta power or an electro-hydraulic pump was connected to a fitt8ngbon the n7t and pressure was applied to the "hollow" nut. This caused the nut to clamp tightly to the threads on the line shaft. The only time we ever used a sledge hammer to remove a nut was on a slugging wrench that fit to that nut.
