Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: Repurposing a Torx Bit as a Broach.
  1. #21
    Apr 2016
    THOSE TORX QALSO MAKE AWESOME BROKEN STUD REMOVERS!!! DRILL WACK IT IN AND REMOVE STUDS!!! IVE BEEN DOING IT FOR YEARS WITH THOSE.
  2. #22
    Apr 2016
    Centurion, South Africa
    Nice solution.
    Could one not use grub screws (they come in 3/8 x 3/8 24 and are available off the shelf) with allen socket, they come in both stainless and HT or do they need to be brass.
    "I don't know why these aren't available off the shelf... Not only do they provide for clearance I need but I think they look 100% better then those tall plugs do. My plug is on the right."
  3. #23
    May 2012
    Byron, Michigan
    astroracer's Tools
    Quote Originally Posted by Tonyg View Post
    Nice solution.
    Grub screws are just set screws. They don't have the correct seat to seal the flare on the inside of the fitting. You will see I had to make that seat as well in post 2. Brass is also a better material as it will deform a bit to help make the seal without tearing up the seat it is sealing against.
    Mark
  4. The Following User Says Thank You to astroracer For This Useful Post:
    Tonyg (Apr 21, 2021)
