Results 1 to 8 of 8
Thread: Result of downshifting to first gear at high speed - GIF
    May 2024
    emu roo (Aug 17, 2025)
    Supporting Member bob_3000's Avatar
    Aug 2020
    That must have sounded and felt terrible.
  4. The Following User Says Thank You to bob_3000 For This Useful Post:
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    This is known in car circles as the Money Shift.
    Neil
  6. The Following 4 Users Say Thank You to sossol For This Useful Post:
    bob_3000 (Aug 17, 2025), emu roo (Aug 17, 2025), PJs (Aug 14, 2025), rdarrylb (Aug 15, 2025)
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Quote Originally Posted by sossol View Post
    Neil
    Also known as grenading...
  8. The Following User Says Thank You to BuffaloJohn For This Useful Post:
    hemmjo's Tools
    I used to wrench for a large landscape contractor. They were located down a steep grade off the highway. One day I heard the big old dump truck returning from picking up a load of gravel.
    The driver pulled in off the highway in low gear but never bothered to shift heading down the hill. Which would have been ok had he used the brakes to help keep the speed down. Instead, he pushed the clutch in. You know that sound of a turbo spooling up. Imagine that sound X 100 as the straight cut gears in that old transmission spooled up til they just could not take any more!!
    Oh what a mess that was.
  10. The Following 3 Users Say Thank You to hemmjo For This Useful Post:
    bob_3000 (Aug 17, 2025), BuffaloJohn (Aug 17, 2025), emu roo (Aug 17, 2025)
  11. #6
    Dropping a driveshaft or a transmission grenade on you on a steep down grade is one thing you only want to experience once. You might not survive the next time.
    Big baldy also known as Cabbage pass in Eastern Oregon used and may still have signs posted on the down grade stating what gear and speed was the maximum safe speed for the number of axles and weight you had. Bigger engines with jake brakes and 18 speed or auto shift transmissions and better brakes have done a lot to alleviate downhill dangers, but you still don't want to go down Black Mountain at 60 MPH with a load of slinky. Unless you are as good as Sandra Bullock and can drive with half your wheels in the air.
  13. #7
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Driven that many times, yes the warnings are still there. They are also on the Siskiyou Summit has similar warnings (drove that just a few weeks ago). You know when there are more than a one run-away truck ramp that the road is a challenge...
  14. #8
    Quote Originally Posted by BuffaloJohn View Post
    And you know in some states the cops are there for nothing but revenue collecting tools for corrupt Politian's when they are ordered to write a trucker a huge fine for having to use the emergency off ramps
