Results 1 to 4 of 4
Thread: retired machinist and CNC programer, operator
    Dec 2016
    I like in Georgia. Hobby is wood working now.
    I like to keep up with what is new. Jacky
  2. #2
    Hi Jacky - welcome to HomemadeTools.net
    What are you thinking of building next? Can we help out with any ideas?
  3. #3
    Dec 2016
    LATHE DIVIDING HEAD
    I thought the reader might be interested in a hobby shop project I did back in 1980. I bought a 12” x 36” metal lathe from Sears. It has a 10 thread cross carriage thread and the dial was radial. One round = .100” travel and .200” off the part. If you move the dial .010” then your part is .020” smaller. I wanted a diametrical dial. If I wanted my part to be .030” smaller then I turn the dial .030” smaller.
    SOLUTION:
    1- I turned a stainless steel ring with a slip fit over the factory dial.
    2- I mounted a 50 tooth sprocket on the back side of the lathe spindle.
    3- I rigged a jack-shaft with a 10 tooth sprocket connected with a chain to the 50 tooth. That gave me a 5:1 ratio.
    4- I locked a 40 tooth sprocket on the jack-shaft. 40 x 5 = 200 divisions. (One tooth on the 40 tooth sprocket = 1/200 revolution of the chuck.
    5- I mounted a v sharp tool sideways and cut the 200 divisions with every 5th line longer.
    6- Then I stamped every 10th line with numbers.
    7- I put a thumb screw to lock it in place and it worked perfect. I did a number of parts with a ± 1/10,000” tolerance. Sorry I don’t have any pictures. It was still on the lathe when I sold it a few years ago. Maybe someone can use this information. Jacky
  4. #4
    Very interesting; too bad the tool was sold.
    Keep us posted on your new builds
