Just incase someone doesn't read the other thread Siamese cylinders are matted side by side with the rods facing in opposite directions. some manufactures do this instead of having to use a double acting telescopic cylinder. Siamese double acting cylinders are simpler to make than a telescopic cylinder which is also required to exert force while retracting also you can achieve a longer stroke in a shorter area than having to use a single long cylinder
