Results 1 to 5 of 5
Thread: Ripping motor windings from housing - GIF
    johncg (Oct 27, 2021), nova_robotics (Oct 26, 2021), rlm98253 (Oct 27, 2021)
    Having rewound a few motors I can say for a fact that those windings came out a lot faster than they went in.
    You might note how even the ends are. That tells me they were cut on the other end before puling them out , other wise they would not come out with 1 pull.
    lassab999 (Oct 26, 2021), Philip Davies (Oct 30, 2021)
    Oct 2017
    i agree w frank s ,,, i do scrapping, and the windings NEVER come out that easy,,, now if u spit the stator in half,,, then it gets easy,, thats what i do
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Quote Originally Posted by madokie View Post
    How do you split it in half? Usually I cut the windings on one side, then hammer a tapered drift through the coils. I have split a couple of small ones, using a sharpened stripping knife, but it destroyed the knife!
    Oct 2017
    i got a bare axe head, and spent some time w angle grinder, thinning it out ,, so its long and thin,,,use a 5# hammer and 20-25 hits later its in half,,,currently working on a hydralic press, using a 1/4 plate sharpened on one end to cut in half..its very easy using a 20 inch pry bar to remove stator wire once u split in half..now the small stators, where the plates are shorter that 2 inches i leave alone and use a chisel to cut off one end of wire ,then remove wire via the prybar..otherwise the plates will bend in the vise and make a mess of removing wire..
  8. The Following User Says Thank You to madokie For This Useful Post:
    Philip Davies (Oct 31, 2021)
