Results 1 to 8 of 8
Thread: Road snow removal sprinklers - GIF
Hybrid View
    nova_robotics (Jan 4, 2023)
    Sep 2013
    Karl_H's Tools
    Is that really the intention or is it simply a re-branding of "broken sprinkler valve?"
    Supporting Member Duke_of_URL's Avatar
    Aug 2018
    Texas
    AKA, "Road Ice Attachment Sprinklers.
    Supporting Member bob_3000's Avatar
    Aug 2020
    Is it sea water/salt water for de-icing?
    Quote Originally Posted by bob_3000 View Post
    It would almost have to be some kind of harsh brine water otherwise it would just freeze and make the road even worse. I wouldn't want to drive through that stuff though, just imagine how corrosive it would have to be on the vehicles
    hemmjo's Tools
    The road crews in this area (Ohio, USA) use brine to pretreat roads when icing conditions are expected. Some trucks are also equipped to spray brine onto the granular material as it is spread on the roads. Either Calcium or Sodium Chloride is used depending on many factors.
    Fresh water freezes at about 32˚f, (0˚c). Sea water typically freezes at about 28.4˚f (-2˚c). I am thinking that sea water would not be an effective ice melting solution, except in a very narrow temperature window. Granular sodium chloride is effective down to 20˚f (-7c), while granular calcium is effective down to -20˚f (-29˚c)
  8. #7
    And all of it will rot your vehicle out from under you while you drive. My 2001 F150 came from CT. it barely has enough frame left under it top hold the axles in place
  9. #8
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    They actually work pretty well and don't ice over for a couple of reasons. First, they are fed with geothermally heated water and don't use any salt, plus the roads in Japan are generally really nice and well drained, so no puddles to freeze to speak of. Second, they are only used for snow removal in areas where they get a lot of snow, but the temps don't get down terribly low. So, the water isn't ever exposed to cold that would freeze it before it drained away. It's all very Japanese.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
