Thread: Rod Storage Array Using PVC Pipe and PVC Glue
    jjr2001's Tools
    I needed a place to keep 12" long or so pieces of brass and some MT2 drill bits.
    Pvc pipe seemed like a good idea but making a face with all the holes for the tubes
    seemed like a lot of work. So, I simply used pvc cement and glued them into a group
    putting a bead of glue on the point of contact of the tubes. Stronger than I could
    imagine and fast to put together. Here is a picture of it all assembled and loaded.
    Two different sizes of pipe were used for the various items to be stored.
    They are separated by a piece of plywood.
    The next picture is the vertical rack attached to the cabinet with "Goop". Really good stuff.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Rod Storage Array Using PVC Pipe and PVC Glue-img_1427a-copy.jpg   Rod Storage Array Using PVC Pipe and PVC Glue-img_1428a-copy.jpg
  2. The Following 2 Users Say Thank You to jjr2001 For This Useful Post:
    AmateurMachinist (Mar 25, 2019), Seedtick (Jan 4, 2018)
    Thanks jjr2001! We've added your Rod Storage Rack to our Racks category,
    jjr2001 (Jan 5, 2018)
