Results 1 to 5 of 5
Thread: Roller knife from meat grinder grate - video
    Roller knife from meat grinder grate. By Mr Deddy. 7:12 video:
  2. The Following User Says Thank You to Jon For This Useful Post:
    Philip Davies (Mar 24, 2023)
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    I like this tool a lot. I have 2 meat grinder grates, but mine have notches, not lugs. So either I must grind 1/8” off the radius, or weld infill, and grind that back, which would be a soft spot. My preferred handle would be wooden, but Mr Deddy’s looks super. He must recharge his batteries often! I have not come across a chuck to fit to an angle grinder before.
    I like this tool a lot. "snip" I have not come across a chuck to fit to an angle grinder before.
    Some of the lighter duty 4inch angle grinders had 10mm threaded arbors You could probably recut the threads in a chuck that had 3/8 threads or find one that was threaded to 10 mm. Or drill out the taper in a pressed on chuck and thread it to 5/8 11 TPI
    Philip Davies (Mar 26, 2023)
    I like this tool a lot. ...
    Philip, if you do make one, do me a favor and include a sheet metal hand guard on the handle so a quick stop of the roller doesn't allow your hand to slide forward into the blade.
    Home Shop Freeware
  7. The Following User Says Thank You to mklotz For This Useful Post:
    Dec 2015
    Reading, Berks, UK
    Thanks, a bit of brass looks nice with rosewood.
