Results 1 to 10 of 21
Thread: rotary table driven by stepper motor controlled by 2 Arduino's
  1. #3
    Berkshire UK
    thehomeengineer's Tools
    Rotary table code Used on Arduino Mega
    #include <Wire.h>
    #include <Keypad.h>
    #include <LiquidCrystal_I2C.h>
    //#include <I2CScanner.h>
    const byte ROWS = 4;
    const byte COLS = 4;
    //****************USER DEFINED**************
    //setup vars
    const int stp = 10; // connect pin D10 to step
    const int dir = 11; // connect pin D11 to dir
    const int StepsPerRotation = 1600; // Set Steps per rotation of stepper NOTE the driver is set to Half step
    const int TableRatio = 90; // ratio of rotary table
    const int stepdelay = 1000; //this is in microseconds
    int delay1 = 2000; //this is used for Splash Screen display time
    byte colPINS[ROWS] = {2, 3, 4, 5}; //pin 1 of keypad to pin 12
    byte rowPINS[COLS] = {6, 7, 8, 9};
    int pot = A0; //potentiometer wiper
    int pot_movement = 0;
    int pot_movement_mapped = 0;
    int adj_speed = 3000; //Speed adjustment (Max mapped uS) Making this LOWER will INCREASE min RPM, making this HIGHER will DECREASE min RPM
    int feed_pot_thresh=5; //Adjust this variable to change when the potentiometer makes the motor move (bigger means more movement to initialise motor)
    int inc = 0;
    int ledbrightness = 120;
    int led_inc = 0;
    int ind_green = 44;
    int ind_red = 46;
    LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address as determined by I2C scanner
    byte degss[] = {
    B00100,
    B01110,
    B01110,
    B01110,
    B11111,
    B00000,
    B00100,
    B00000
    // SCL - A5, SDA - A4, VCC - +5, Gnd - Gnd
    // **************define Debug Macro**************
    //#define DEBUG 1 //delete slashes for printing debug info to serial monitor
    #ifdef DEBUG
    #define DEBUG_Print(x) Serial.print(x)
    #define DEBUG_PrintDec(x,y) Serial.print(x,y)
    #define DEBUG_Println(x) Serial.println(x)
    #else
    #endif
    char keys[ROWS][COLS] = {
    {'1', '2', '3', 'A'},
    {'4', '5', '6', 'B'},
    {'7', '8', '9', 'C'},
    {'.', '0', '#', 'D'}
    Keypad kpd = Keypad(makeKeymap(keys), rowPINS, colPINS, ROWS, COLS);
    int moved;
    long Multiplier;
    long cumSteps = 0;
    float Degrees = 0.; // Degrees from keypad
    long ToMove = 0; // Steps to move
    float bob = 0.; //this tracks current position in degrees
    int cho = 0;
    void setup()
    //lcd.createChar(0, degss);
    #ifdef DEBUG
    Serial.begin(9600);
    #endif
    Multiplier = (long)TableRatio * StepsPerRotation;
    lcd.init(); // initialize the lcd
    pinMode(stp, OUTPUT);
    pinMode(dir, OUTPUT);
    // Print welcome message to the LCD.
    lcd.backlight();
    lcd.print("Rotary Table Control");
    lcd.setCursor(1, 2);
    lcd.print("The Home Engineer.");
    lcd.setCursor(8, 3);
    lcd.print("2019");
    //delay1 = 500;
    //delay (delay1);
    // fade in from min to max in increments of 5 points - indicator LEDs:
    while (led_inc != 2) {
    for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += 5) {
    // sets the value (range from 0 to 255):
    analogWrite(ind_green, fadeValue);
    analogWrite(ind_red, fadeValue);
    // wait for 30 milliseconds to see the dimming effect
    delay(30);
    // fade out from max to min in increments of 5 points:
    for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= 5) {
    delay(30);
    led_inc = (led_inc + 1);
    digitalWrite(ind_red, HIGH);
    digitalWrite(ind_green, LOW);
    lcd.init();
    cho = 0;
    char key = kpd.getKey();
    lcd.print("Degrees "); lcd.print(" = A");
    lcd.setCursor(0, 1);
    lcd.print("Divisions = B");
    lcd.setCursor(0, 2);
    lcd.print("JOG = C");
    lcd.setCursor(0, 3);
    lcd.print("Feed = D");
    while (cho == 0)
    key = kpd.getKey();
    switch (key)
    case NO_KEY:
    break;
    case 'A':
    Degrees = getdegrees();
    lcd.clear();
    cho = 1;
    break;
    case 'B':
    Degrees = getdivisions();
    cho = 2;
    break;
    case 'C':
    Degrees = getjog();
    lcd.clear();
    cho = 3;
    break;
    case 'D':
    Degrees = getfeed();
    lcd.clear();
    cho = 4;
    break;
    } // end case
    } // end while cho=0
    DEBUG_Print("90 = 1"); DEBUG_Println(TableRatio);
    DEBUG_Print("800 = 1"); DEBUG_Println(StepsPerRotation);
    DEBUG_Print("800 = 360"); DEBUG_Println(Multiplier);
    } // end setup
    void loop() // MAIN LOOP
    lcd.clear();
    bob = 0;
    cumSteps = 0;
    lcd.setCursor(7, 0); lcd.print("Total: "); lcd.print(" "); lcd.setCursor(14, 0); lcd.print(bob, 2); // total steps
    lcd.setCursor(0, 3); lcd.print("FOR=A REV=B X=C");
    while (key != 'C') // C will return to start menu
    lcd.setCursor(0, 0); lcd.print(abs(Degrees), 2); lcd.print((char)223);
    key = kpd.getKey();
    if (key == 'A') // FORWARD
    bob = bob + Degrees;
    ToMove = (bob * Multiplier) / 360 + 0.5 - cumSteps;
    cumSteps = cumSteps + ToMove;
    digitalWrite(dir, LOW);
    printadvance();
    if (key == 'B') // REVERSE
    bob = bob - Degrees;
    ToMove = -1*((bob * Multiplier) / 360 + 0.5 - cumSteps);
    cumSteps = cumSteps - ToMove;
    digitalWrite(dir, HIGH); // pin 13
    printadvance();
    } // end while not C loop
    lcd.init();
    setup();
    } // end main VOID
    float getjog() // used to set mechanical ratio and steps per revolution
    float Degrees = 0;
    float num = 0.00;
    lcd.clear();
    lcd.setCursor(6, 0); lcd.print("Jogging");
    lcd.setCursor(0, 1); lcd.print("A=0.5 B=1 C=5 Deg's ");
    lcd.setCursor(0, 2); lcd.print("Choose Degrees:"); lcd.setCursor(0, 3); lcd.print("OK = # "); lcd.print((char)60); lcd.print((char)45); lcd.print(" D");
    while (key != '#')
    switch (key)
    case NO_KEY:
    break;
    case 'A':
    Degrees = 0.5;
    lcd.setCursor(16, 2); lcd.print(Degrees, 1);
    break;
    case 'B':
    Degrees = 1;
    break;
    case 'C':
    Degrees = 5;
    break;
    case 'D':
    num = 0.00;
    lcd.setCursor(15, 2); lcd.print(" ");
    break;
    key = kpd.getKey();
    return Degrees;
    float getdivisions()
    digitalWrite(ind_green, HIGH);
    digitalWrite(ind_red, LOW);
    lcd.noBlink();
    float Degrees = 0;
    float num = 0.00;
    lcd.clear();
    lcd.blink();
    lcd.setCursor(0, 1); lcd.print("Enter Division:");
    lcd.setCursor(16, 1);
    while (key != '#')
    switch (key)
    case NO_KEY:
    break;
    case '0': case '1': case '2': case '3': case '4':
    case '5': case '6': case '7': case '8': case '9':
    num = num * 10 + (key - '0');
    lcd.print(key);
    break;
    case 'D':
    num = 0.00;
    lcd.setCursor(16, 1); lcd.print(" ");
    break;
    Degrees = 360 / num;
    key = kpd.getKey();
    return Degrees; //num;
    float getfeed()
    lcd.noBlink();
    //int key = 0;
    float num = 0.00;
    float decimal = 0.00;
    float decnum = 0.00;
    int counter = 0;
    lcd.clear();
    //lcd.init();
    lcd.setCursor(2, 0);
    lcd.print("Use potentiometer");
    lcd.setCursor(2, 1);
    lcd.print("to set the speed");
    lcd.setCursor(5, 2);
    lcd.print("of rotation");
    delay(1500);
    lcd.clear();
    lcd.setCursor(0, 1); lcd.print("Enter Degrees:"); lcd.setCursor(0, 3); lcd.print("OK = # "); lcd.print((char)60); lcd.print((char)45); lcd.print(" D");
    lcd.setCursor(15, 1);
    lcd.blink();
    bool decOffset = false;
    while (key != '#')
    switch (key)
    case NO_KEY:
    break;
    case '.':
    if (!decOffset)
    decOffset = true;
    lcd.print(key);
    break;
    case 'D':
    num = 0.00;
    lcd.setCursor(15, 1); lcd.print(" ");
    break;
    if (!decOffset)
    lcd.print(key);
    else if ((decOffset) && (counter <= 1))
    lcd.print(key);
    counter++;
    break;
    } //end case
    decnum = num / pow(10, counter);
    key = kpd.getKey();
    } //end while not #
    return decnum;
    } // end getdegrees
    float getdegrees()
    lcd.noBlink();
    //int key = 0;
    float num = 0.00;
    int counter = 0;
    lcd.clear();
    //lcd.init();
    lcd.blink();
    while (key != '#')
    switch (key)
    case NO_KEY:
    break;
    case '.':
    if (!decOffset)
    decOffset = true;
    lcd.print(key);
    break;
    case 'D':
    num = 0.00;
    break;
    if (!decOffset)
    lcd.print(key);
    lcd.print(key);
    counter++;
    break;
    } //end case
    key = kpd.getKey();
    } //end while not #
    return decnum;
    } // end getdegrees
    void printadvance() // print function
    lcd.noBlink();
    lcd.setCursor(6, 1); lcd.print("Moving");
    rotation(ToMove, 0);
    lcd.setCursor(6, 1); lcd.print(" ");
    void rotation(long tm, int d)
    DEBUG_Print("Total Degrees = "); DEBUG_PrintDec(bob, 3); DEBUG_Print(" Steps to move = "); DEBUG_Print(tm); DEBUG_Print(" Total Steps = "); DEBUG_Println(cumSteps);
    if (cho == 4 || cho == 2) {
    for (long i = 0; i < tm; i++) //tm == To Movement
    //pot_movement = analogRead(pot);
    pot_movement_mapped = map (analogRead(pot), 0, 1023, 0, adj_speed);
    if(pot_movement_mapped<(adj_speed-feed_pot_thresh)){//only move if the pot is above a threshold
    digitalWrite(stp, HIGH);
    delayMicroseconds(pot_movement_mapped);
    digitalWrite(stp, LOW);
    else{//decrement i if the motor hasn't been moved to ensure full motion is acheived
    i--;
    else {
    for (long i = 0; i < tm; i++) //tm == Total Movement
    delayMicroseconds(stepdelay);
    void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
    asm volatile (" jmp 0");
  2. The Following 7 Users Say Thank You to thehomeengineer For This Useful Post:
    brianr47 (Jan 27, 2025), byates (Jun 1, 2023), emu roo (Sep 25, 2025), fizzloid (Jul 21, 2022), Home-PC (May 30, 2023), Jon (Jan 17, 2020), Paul Jones (Jan 15, 2020)
