Hi All
This is the progress so far on the motorisation of my rotary table. Both the table and tail-stock were striped down for cleaning as I had to make a new modified worm shaft for 14mm Flexible Plum Coupling, so thought it would be a good idea as I had to take some of the table apart to get the old shaft out. rotary table worm shaft
Unfortunately I got a bit carried away and decided a re-paint would be a good idea
So all the the castings were striped down to bear metal and sprayed. I have reassembled both table and tail-stock and I am happy with the result even though I did wonder if it was worth it at the start.
The next part of the build will be a mounting bracket to go between the Nema 34 stepper motor and the table. Below are some photos of the project
Old green painted casting striped down for cleaning
Items sprayed incomplete scruffy spray booth
Main Rotary Table casting
Masking tape removed
Items ready for assembly
Part assembled
Tail-stock
Completed ready for stepper motor etc.
14mm shaft for Flexible Plum Coupling
I will update the next parts in the near future
Thank you for viewing
The Home Engineer
