Results 1 to 6 of 6
Thread: Rotary table re-ferb ready for stepper motor
    Berkshire UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thehomeengineer's Tools
    Hi All
    This is the progress so far on the motorisation of my rotary table. Both the table and tail-stock were striped down for cleaning as I had to make a new modified worm shaft for 14mm Flexible Plum Coupling, so thought it would be a good idea as I had to take some of the table apart to get the old shaft out. rotary table worm shaft
    Unfortunately I got a bit carried away and decided a re-paint would be a good idea
    So all the the castings were striped down to bear metal and sprayed. I have reassembled both table and tail-stock and I am happy with the result even though I did wonder if it was worth it at the start.
    The next part of the build will be a mounting bracket to go between the Nema 34 stepper motor and the table. Below are some photos of the project
    Rotary table re-ferb ready for stepper motor-old-painted-casting-striped-down-cleaning.jpg
    Old green painted casting striped down for cleaning
    Items sprayed incomplete scruffy spray booth
    Main Rotary Table casting
    Masking tape removed
    Items ready for assembly
    Part assembled
    Tail-stock
    Completed ready for stepper motor etc.
    14mm shaft for Flexible Plum Coupling
    I will update the next parts in the near future
    Thank you for viewing
    The Home Engineer
  2. The Following User Says Thank You to thehomeengineer For This Useful Post:
    MeJasonT (10-20-2019)
    Marion, Iowa
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    metric_taper's Tools
    I'm curious about how your going to mount the motor. I had to look up Flexible Plum Coupling, and I think this is called a Jaw coupling here in the states.
    Is that some sort of additional platen that you made that has the parallel T-slots? Seems that would be handy for some setups vs. the radial slots.
    Berkshire UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi metrc_taper
    There is an additional plate on the table which is very handy for two reasons: like you have pointed out the additional tee-slots and secondly the increase in diameter significantly improving the clamping area. I would like to say it was my idea but I bought the table from a friend who was clearing his late fathers workshop and he made the plate. The tailstock was a good find that just happened to be the correct size. Can’t remember where I found it
    The motor I have is a Nema 34 and I will be making a adapter/housing to join both the table and motor but I am waiting on the coupler to arrive so I can ensure the dimensions etc are correct. I did order a coupling but somehow bought the wrong bore size.
    Thank you for your interest
    Marion, Iowa
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sounds like you are having the motor do a direct drive without a gear box.
    I've been wanting to do this to my 12" RT as well. I've watched a few threads on the "Home Model Engine Machinist" forum. "Interrupt Driven Rotary Table Controller" and "Arduino Rotary Table for Dummies". Both are Arduino based.
    Berkshire UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It is direct drive (or I should say it will be��) hope to finish the control side of things this week and then make the motor mount when the coupler arrives. I have seen lots of good ideas and have tried to in corporate all the bits I like and more
    Which includes a power feed mode and all good electronic projects need LED’s. It has got to the stage where I am running a mega and nano arduino to drive the system.
    Will post when happy with controller.
    The Home Engineer
    Supporting Member MeJasonT's Avatar
    Lake District in UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    MeJasonT's Tools
    Thehome engineer
    What is the amperage of your nema 34 stepper motor, if it operates around 4A and you message me you may find i have something interesting to share.
    Post your reply!
    Join 42,532 of us and get 100+ tool plans, tool eBooks, build guides, and much more.
    59 Best Homemade VisesTube Bender Build Guide
    Citizen of the Undemocratic Republic of Britain
