Results 1 to 6 of 6
Thread: rotary table worm shaft
    Berkshire UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thehomeengineer's Tools
    Hi All
    Yesterday I spent the day making a new worm shaft for my rotary table. The reason for this, I am currently trying to make this motorised. controlled via an Arduino and stepper motor. As I need to find away of coupling the shaft of the rotary table to the stepper motor I didn't want to make modification to the existing shaft just in case I ever need to convert back to manual table.
    The last time I cut a worm was in my apprentice days so a bit of head scratching and research it all came flooding back.
    The first thing was to remove the existing shaft so I could get some measurements. As I could measure the pitch this was a good starting point and the table being made in Spain I was guessing it would be a Module gear? so to calculate the Mod=Pitch/Pi. So Mod=6,28/3.14= Mod 2,
    I then calculated the helix angle to ensure I had enough lead clearance when setting the tool and cutter to cut the HSS tool. The helix angle is simple trigonometry. First the opposite side is the pitch and the adjacent side = (Pi x Dia of shaft) which equates to one full thread.
    The shaft blank was machined and the lathe gear box/gear train set to the Mod 2 mode.
    Gear selection chart
    Mod gear train
    Standard low range gear train I normally use
    First few passes.
    Retracting tool makes the process a lot easier
    Milling oilway and lock washer tab slot
    Finished worm
    Both shafts
    Assembled new shaft assembly
    Rotary table casting
    Thank you for viewing
    The Home Engineer
  2. The Following 10 Users Say Thank You to thehomeengineer For This Useful Post:
    Altair (10-12-2019), Bony (10-21-2019), DIYSwede (10-14-2019), Frankd68 (10-15-2019), Jon (10-12-2019), mwmkravchenko (10-14-2019), olderdan (10-12-2019), rossbotics (10-19-2019), shopandmath1 (10-13-2019), Toolmaker51 (10-14-2019)
    Altair's Avatar
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks thehomeengineer! We've added your Rotary Table Worm Shaft to our Machining category,
    Oct 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good job this is not easy to do
  5. The Following User Says Thank You to shopandmath1 For This Useful Post:
    thehomeengineer (10-14-2019)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Probably my favorite tooling; powered rotary tables.
    I hunt periodically for a driven table suitable for my Kearney-Trecker 2D. It has the PTO. But powered independently DC and speed control offers different [infinite] feed options.
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Awesome job! Simple when you finally remember how you did it the first time right!
  8. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    thehomeengineer (10-18-2019)
    Aug 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    wizard69's Tools
    Boy do I know that feeling one gets when repeating something done or learned years ago.
    In any event looks like you are off to a great start, I’m expecting a working table any day now ����!
    Post your reply!
    Join 42,532 of us and get 200+ tool plans, tool eBooks, build guides, and much more.
    eBooks for Supporters
