Results 1 to 8 of 8
Thread: Rotating ball nut assembly for fast linear cnc motion
    Supporting Member Bongodrummer's Avatar
    Dec 2013
    Wales
    Bongodrummer's Tools
    Hi all,
    So I've been holding off posting the rotating ball nut setup we've been making utill I got it working well... Time will still be the test, but ATM I'm quite chuffed with it
    Basically, its a way to access the precision and speed of a LONG ballscrew, without the need to spin, accelerate and decelerate the big massive screw that has comparatively huge inertia.
    Here's an explanation and how the system goes together.
    Bongodrummer
    Subscribe to my Youtube Channel
    FloweringElbow.org Blog
    Flowering Elbow on Facebook
  2. The Following 6 Users Say Thank You to Bongodrummer For This Useful Post:
    emu roo (Dec 17, 2021), freddo4 (Dec 16, 2021), Jon (Dec 16, 2021), mwmkravchenko (Dec 16, 2021), nova_robotics (Dec 20, 2021), Tonyg (Dec 17, 2021)
    Dec 2013
    Wales
    And here it is, actually in action after a lot of fettling and a change of ballscrew pitch!
    Bongodrummer
  4. The Following 3 Users Say Thank You to Bongodrummer For This Useful Post:
    nova_robotics (Dec 20, 2021), PJs (Jul 27, 2025), Tonyg (Dec 17, 2021)
    Thanks bongodrummer! We've added your Rotating Ball Nut Assembly to our CNC category,
    as well as to your builder page: bongodrummer's Homemade Tools. Your receipt:
  6. The Following User Says Thank You to DIYer For This Useful Post:
    Feb 2019
    clavius's Tools
    I believe there were a few versions of the Bridgeport Boss series of mills that uses a similar system where the nut is spun rather than the leadscrew. I understand that the idea was that the lead screw was always in tension and would not flex and whip as it would if it were spun at high speeds for moving the table.
    nova_robotics's Tools
    Excellent work. I'm seriously impressed. Keep the videos coming!
    Quote Originally Posted by clavius View Post
    My Bridgeport has a rotating nut for the Z axis.
    Apr 2012
    NorCal
    Saltfever's Tools
    I understand your concerns about inertial effects on a long shaft and revolving the nut to compensate is a good idea. Thanks for sharing your results. I see the Y axis assembly has a lot of aluminum in it and, of course, a heavy spindle. So I am assuming the mass of the Y assembly is probably equal to or greater than the mass of the X ball screw. Even though the Y axis has a different CG location and structural shape, acceleration of similar (or greater) mass has issues as well. Are we primarily concerned with the LONG spinning X shaft and not the shorter Y assembly? Is there anything to be gained by revolving the Y nut?
  11. The Following User Says Thank You to Saltfever For This Useful Post:
    PJs (Jul 27, 2025)
  12. #8
    Quote Originally Posted by Saltfever View Post
    That's a very excellent point and quite an interesting thing to think about. The moment of inertia increases as a square of the radius. So a light 3" rotating nut might still have a greater moment of inertia than a heavy 0.75" rotating shaft. It would be interesting to do an analysis.
  13. The Following User Says Thank You to nova_robotics For This Useful Post:
    PJs (Jul 27, 2025)
