Thread: Rotating Welding Positioner Project
    Supporting Member tmate3's Avatar
    Jan 2021
    tmate3's Tools
    I decided to use an older Troyke 9" rotary table I had on hand as the basis for a welding positioner. I made an adaptor plate to mount it on a drill press rig with a 12" high column. This gives it the ability to tilt 90 degrees to either side, and swivel to either side as needed to distribute the weight.
    It will be driven by a variable speed gear motor through a timing belt and pulleys. If necessary, the speed range can be tweaked by changing the size of the timing pulleys.
    At present, I'm working on a mount that places the motor out of the way under the table. Waiting for some steel to arrive.
  2. The Following User Says Thank You to tmate3 For This Useful Post:
    that_other_guy (Dec 13, 2022)
    Jan 2021
    tmate3's Tools
    All finished except for the grounding arrangement. Pic below shows how I plan to do that.
    Rotating Welding Positioner Project-positioner.jpg Rotating Welding Positioner Project-grounding-detail.jpg
    Thanks tmate3! We've added your Welding Positioner to our Welding category,
    as well as to your builder page: tmate3's Homemade Tools. Your receipt:
    Jan 2021
    tmate3's Tools
    Finished with welding positioner project:
    Rotating Welding Positioner Project-w-vise-1_75mb.jpg Rotating Welding Positioner Project-45-degrees.jpg Rotating Welding Positioner Project-90-degrees.jpg Rotating Welding Positioner Project-support-table.jpg
    Lake Tahoe
    IntheGroove's Tools
    You could make an apron from a welding blanket to keep splatter off...
