https://youtu.be/MS7Q9RcaNmw
https://makethingswithrob.com/router-dog-hole-table/
Thanks Make Things! We've added your Router Dog Hole Table to our Routing category,
as well as to your builder page: Make Things's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-router-dog-hole-table"> <img src="/uploads/273729/homemade-router-dog-hole-table.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-router-dog-hole-table">Router Dog Hole Table</a> <span> by <a href="https://www.homemadetools.net/builder/Make+Things">Make Things</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/router-table'>router table</a> </div> </div> </div> </div>
What you actually did was counterbore for the end of the bolt, not countersink. Also, it is usually referred to as a center drill, not a center drill bit. Most machinists will refer to "drill bits" as twist drills. And having worked with contractors quite a bit, they will call a handheld power drill a drill motor. I never asked but I think it is to differentiate it from a drill (twist drill) that will be chucked up in it. I always learn something from you. You have some unique ways to solve simple problems.
