Results 1 to 10 of 14
Thread: Saw not cutting stright
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    While sawing up the material for the retractable internal tool holder on my 4x6 band saw I noticed how out of square it was cutting. When cutting smaller sections it is not that noticeable but as the stock size increases, it magnifies the error. This is the simply method I used to realign the bearing guides and the saw is again cutting straight. This poor little saw is now 20 years plus and sits in the workshop and gets used and abused with next to no maintenance but is still going strong.
    The first couple of photos show the problem
    The next photos show how I fixed the saw issue. To try to place a square against a ½” blade to check it is vertical is quite difficult. To overcome this a 6” rule clamped with a small tool makers clamp to the edge of the saw blade gives a good indication on how far the saw is out. With a square placed against the rule, both bearing guides are set until the rule is upright and therefore making the blade square to the base of the saw vice.
    Saw not cutting stright-img_0553.jpg Saw not cutting stright-img_0554.jpg Saw not cutting stright-img_0555.jpg Saw not cutting stright-img_0556.jpg
    The last photo shows the saw once again is cutting square.
    Many thanks for taking the time to view
    The Home Engineer
  2. The Following 29 Users Say Thank You to thehomeengineer For This Useful Post:
    Andyt (Oct 5, 2018), Canobi (Oct 9, 2020), Drew1966 (Jan 31, 2023), emu roo (Oct 25, 2024), fizzloid (Feb 22, 2023), freddo4 (Feb 21, 2023), garage nut (Jan 9, 2019), greyhoundollie (Jan 11, 2019), Karl_H (Jan 17, 2019), kboy0076 (Feb 22, 2023), Ken Koch (Oct 5, 2018), lassab999 (Feb 22, 2023), Lima2088 (Jun 4, 2018), lpresson (Nov 9, 2022), martink (Jan 25, 2018), melbakid (Feb 14, 2022), NickP (Jan 25, 2018), NortonDommi (Jun 5, 2018), nova_robotics (Feb 10, 2022), Paul Jones (Jan 25, 2018), PJs (Jan 28, 2018), rlm98253 (Aug 31, 2023), Seedtick (Jan 25, 2018), Sprig1 (Oct 5, 2018), Tonyg (Oct 9, 2020), tooly (Oct 8, 2020), TrickieDickie (Feb 21, 2023), Tule (Feb 11, 2022), yvonf (Feb 11, 2022)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Home Engineer,
    Good advice and am now curious about the accuracy of my Enco 4X6 bandsaw. I tend to take it for granted that it would remain very close to being in alignment after my initial setup. I checked this morning and the bandsaw blade was not perfectly aligned relative to the saw vise table and as you can see below. I checked by clamping a stiff 6" rule to the saw blade with a Kant Twist clamp and compared the 6" rule gap with a combination square. There was a significant gap at the top and had to be corrected.
    I now fixed the errors in the blade vertical alignment and also the right angle to the stationary vise jaws. Periodically checking is the best approach rather than wasting metal stock.
    Thank you,
    Paul
  4. The Following 3 Users Say Thank You to Paul Jones For This Useful Post:
    lpresson (Nov 9, 2022), PJs (Jan 28, 2018), thehomeengineer (Jan 25, 2018)
    If I might add I have used a very similar method for setting up saw blades on various size band saws for years the only thing was though I found that it was often a little tedious trying to clamp the scale to the blade with the small makers clamp while at the same time holding the scale positioned just above the teeth of the blade so as not to incorporate the set of the teeth into the the mix. so I made a pair of slotted gauges to fit which ever saw I needed to adjust
    they looked something like this Just a piece of sq stock with a slot cut into the end and a thumb screw to tighten it to the blade, the depth of the slot was just shy of being deep enough to reach the teeth. We made them and included a pair to fit the blades of every band saw we sold
  6. The Following 20 Users Say Thank You to Frank S For This Useful Post:
    Al8236 (Jan 26, 2018), baja (Oct 9, 2020), Canobi (Oct 9, 2020), emu roo (May 11, 2024), fizzloid (Feb 22, 2023), garage nut (Jan 9, 2019), lpresson (Nov 9, 2022), martink (Jan 25, 2018), Moby Duck (Jan 26, 2018), NickP (Jan 25, 2018), NortonDommi (Jun 5, 2018), Paul Jones (Jan 25, 2018), PJs (Jan 28, 2018), thehomeengineer (Jan 25, 2018), Tonyg (Oct 5, 2018), Toolmaker51 (Jan 26, 2018), tooly (Jun 2, 2018), TrickieDickie (Feb 21, 2023), Tule (Feb 11, 2022), yvonf (Feb 11, 2022)
    Thanks thehomeengineer! We've added your Bandsaw Guide Alignment Method to our Measuring and Marking category,
    Thanks Frank S! We've added your Bandsaw Blade Setting Tool to our Measuring and Marking category,
    I do almost exactly what Frank S uses. Mine is 5/8'' round stock about 7'' long. 2 #8 screws secure separate clamp. It fits entire blades, from 1/2'' to 1 1/2'' wide, and relief for teeth in both halves. 1/2'' is for my small power hacksaw.
    I raise saw frame as if 6'' stock was in the vise. Clamp the bar on and get it vertical [front to back] with a solid square. The round shape creates somewhat a knife edge for the square and very easy to see discrepancy.
    It's at work and I'm at home...I'll post a picture come next week. There was NO such internet thing when I made it.
  10. The Following 3 Users Say Thank You to Toolmaker51 For This Useful Post:
    Frank S (Jan 26, 2018), PJs (Jan 28, 2018), TrickieDickie (Feb 21, 2023)
  11. #7
    May 2017
    deleted duplicate post
  12. #8
    May 2017
    Home Engineer,
    Good advice and am now curious about the accuracy of my bandsaw.
    Thank you,
    Paul
    Agreed.
    For those who want to do a full checkout of how to set up band saws I recommend you go to youtube and check out Alex Snodgrass's bandsaw clinic. He works for a band saw accessory manufacturer and specializes in woodwork but most of his tips and tricks apply equally to metalwork.
    PS - I was hoping that you were referring to straightening a bent frame - the previous owner of the saw I just bought obviously left it fully tensioned with a heavy blade in it for some time as the upper support is in line with the blade when full up and over 10mm away from the blade when down near the table. Naturally the ebay photos did not show this. I am looking at making a wedge shaped version of the standard height insert that will move the upper frame forward while the angle kicks the top guide post back to true vertical.
  13. The Following 3 Users Say Thank You to MiTasol For This Useful Post:
    oldcaptainrusty (Feb 2, 2018), Paul Jones (Feb 8, 2018), thehomeengineer (Feb 2, 2018)
  14. #9
    Berkshire UK
    great video learnt a lot about setting the bearing guides and blade tension.
    The Home Engineer
  15. #10
    Another Alex Snodgrass bandsaw vid:
