Collaboration is a wonderful thing. After people saw my last video on this subject, many great suggestions were made. The result is a far simpler way to cut thin aluminum angle stock:
https://www.youtube.com/watch?v=Yb1t...xybveyBDVOHXxw
Rick
Rick
Thanks for the tip Rick! Never thought of using a sacrificial block.
Al
You use the block to support the angle stock but it is set back so the blade does not hit it.
Rick,
What a great idea! This opens up a whole new way for us to easily cut thin walled metal structures.
Thank you for the update,
Paul
Yes, this idea is much better, and a piece of wood is more readily available.
Thanks Rick! I've added your Aluminum Angle Cutting to our Bandsaws category, as well as to your builder page: Rick Sparber's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="/aluminum-angle-cutting"><img src="/uploads/105701/aluminum-angle-cutting.jpeg" alt="Aluminum Angle Cutting" /></a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="/aluminum-angle-cutting">Aluminum Angle Cutting</a> <span> by <a href="/builder/Rick+Sparber">Rick Sparber</a></span> </div> <div class="tags"> tags: <a href="/tag/bandsaw">bandsaw</a>, <a href="/tag/angle">angle</a>, <a href="/tag/cutting">cutting</a> </div> </div> </div> </div>
This thread has been moved to the Must Read subforum. Congrats (and thanks) to Rick for making such a valuable contribution!
That should work on tubing as well. Insert a snug fitting dowel rod before cutting.
gotta keep this in mind, thanks for posting.
Ralph
Thanks!. You could also title this "how to save time , money, and eliminate frustration". I am going to make one now. Cheers.
