Results 1 to 8 of 8
Thread: Screw trimming jig plate (for lack of better words)
  1. #5
    Quote Originally Posted by mattthemuppet View Post
    You're welcome! Another idea - if you can find an outside deburrer small enough (like the ones they use on pipes), you could add a small chamfer to the ends of the screws to make them easier to start in holes..
    I keep meaning to build myself a cut screw end deburrer to run on a Dremel. Cut a 60 deg female cone in the end of a piece of rod, glue some emery paper inside the cone, mount on a 1/8" shaft to fit a Dremel collet and Bob's your sister's brother.
  2. The Following User Says Thank You to mklotz For This Useful Post:
    Paul Jones (Jan 6, 2017)
