Results 1 to 9 of 9
Thread: Screwhead chuck
    Jul 2014
    France, Brittany !
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Christophe Mineau's Tools
    Screwhead chuck
    Hi,
    I have always been attracted by the lantern chucks I have seen posted here at HMT, and have planned to make one, one day ...
    But as I was recently shopping at the local hardware store, suddenly the light came. I saw a kind of big hose brass fitting like this one :
    I thought that I could do something quick with that, just adding a brass cap nut and a core screw in order to hold any hex screw driver tip to lock the screw against the cap.
    Here are the main parts :
    - on the left, I machined and tapped a sleeve that will be "loctited" inside the brass.
    - the M10 screw will have to get an hex female hole at the end to receive an hex bit like the one above on the picture.
    - The brass body has its main part turned down to make the shaft
    - The cap was surfaced true, on both sides, and a 8 mm hole is center drilled.
    And here the collection of bushings in order to fit any screw diameter : 2, 2.5, 3, 3.5, 4, 4.5, 5, 6
    they are lightly counter sunk in order to fit either flat or counter sunk headed screws
    The screw head has been (badly) knurled and the hex tip has been made.
    That's actually the most difficult part of the job. I drilled a hole smaller that the hex diagonal and then pressed an hex tip in it.
    I removed it and tried to file the inside with small files and a dremel in order to get a slip fit.
    I had to use a dye to readjust the somewhat expended threads as well.
    And here is the assembly and mounted on the lathe.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 23 Users Say Thank You to Christophe Mineau For This Useful Post:
    Carnel (09-25-2020), Corm (08-31-2018), high-side (09-26-2020), janders1957 (09-01-2018), Jon (05-02-2018), LMMasterMariner (05-02-2018), mklotz (09-01-2018), Moby Duck (05-02-2018), nova_robotics (09-24-2020), olderdan (05-02-2018), Paul Jones (05-02-2018), philipUsesWood&Brass (08-30-2018), PJs (05-02-2018), rayh__ (09-24-2020), reysl1949 (09-25-2020), rgsparber (08-30-2018), rlm98253 (08-30-2018), rossbotics (05-03-2018), Seedtick (05-02-2018), Sleykin (05-02-2018), that_other_guy (08-30-2018), Toolmaker51 (05-02-2018), volodar (01-29-2019)
    May 2014
    Del Mar, California
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Paul Jones's Tools
    Christophe,
    I like your adaptation of the hose brass fitting. Thank you for all the details for making the screw chuck.
    Regards,
    Paul
  4. The Following User Says Thank You to Paul Jones For This Useful Post:
    PJs (05-02-2018)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Christophe Mineau! We've added your Screwhead Chuck to our Workholding category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    Dec 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ralphxyz's Tools
    Nice, Thanks!!
    Ralph
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Some other thoughts re the threaded rod with the hex hole...
    Buy a cheap screwdriver already fitted with a hex socket and retaining magnet.
    Cut off the end and thread and attach knurled thumb knob.
    or
    Turn down rod and loctite into a hole drilled into an appropriate sized bolt
    Home Shop Freeware
  8. The Following User Says Thank You to mklotz For This Useful Post:
    Carnel (09-25-2020)
    Jul 2014
    France, Brittany !
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Ralph and Marv, good point, if I had to redo, I would try that.
  10. #7
    Feb 2015
    Prescott, AZ
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Shelly142's Tools
    Christophe,
    Nicely done. I especially like the utilization of as many off the shelf items as possible.
    Like you said there are many different approaches to lantern chucks and this one can
    be added to the mix. Thanks for sharing.
  11. #8
    Jul 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I very much enjoy it when things are repurposed to ones special needs.
    You did a good job.
    Thanks for posting.
  12. #9
    Aug 2012
    Australia
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    desbromilow's Tools
    or
    or use a 5/16" SHCS since the socket on that is 1/4" hex - that's what I did with my lantern chuck.
    Post your reply!
    eBooks for Supporters
