Results 1 to 10 of 15
Thread: Self made Bench grinder for waste cutting discs
Hybrid View
    Supporting Member liberal's Avatar
    Nov 2018
    liberal's Tools
    Thumbs up Self made Bench grinder for waste cutting discs
    Hi everyone! This Bench Grinder is made of an old motor from a washing machine. Also use cutting discs are mounted on it.
    Here the photo in the maximum resolution: https://photos.app.goo.gl/PPp8dAmDA5TVj3s97
    Self made Bench grinder for waste cutting discs-dsc04751.jpg Self made Bench grinder for waste cutting discs-dsc04752.jpg
    Self made Bench grinder for waste cutting discs-dsc04753.jpg Self made Bench grinder for waste cutting discs-dsc04754.jpg
    Self made Bench grinder for waste cutting discs-dsc04755.jpg Self made Bench grinder for waste cutting discs-dsc04756.jpg
  2. The Following 13 Users Say Thank You to liberal For This Useful Post:
    Corm (Nov 15, 2018), Jon (Nov 14, 2018), jrouche (Nov 15, 2018), PJs (Nov 18, 2018), Priemsy (Feb 14, 2019), rossbotics (Nov 15, 2018), Seedtick (Nov 14, 2018), Slim-123 (Nov 7, 2020), sossol (Nov 14, 2018), Texf1 (Nov 15, 2018), Toolmaker51 (Nov 14, 2018), will52100 (Nov 14, 2018), zarembak (Nov 14, 2018)
    This grinder is accident waiting to happed
    Quote Originally Posted by G.Paul View Post
    Yes, a wheel guard is in order. Then I'd feel safe in trusting the discs though, being made for ~10,000 rpm. Can't figure how to get them round, they'll eat a conventional dresser.
    Also prods thought if a single disc would grind HSS lathe bit chip breakers and maybe overall cutting edges.
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    I dig the color selections.
    Actually with the exception of not having a guard it is probably safer than 99% of the conventional bench grinders or at least the wheels.
    that motor may turn at a max of 1/3 the rated RPM of those wheels when they are new and full diameter. Sandwiched together as they are would make it impossible to damage 1.
    As far as dressing them and truing the OD they will eventually true them selves if the operator continuously moves his work piece back and forth. focusing on the high spots. it won't ever be as smooth as a finely dressed grinding wheel but near enough. I used to stack as many as 10 new 1/4" thick 4" wheels on my old B&D straight grinder for finishing out the bores of pin locations on cat equipment I usually glued them together to maintain the stack up when not in use though.
  7. The Following 6 Users Say Thank You to Frank S For This Useful Post:
    baja (Nov 7, 2020), DIYer (Nov 16, 2018), Priemsy (Feb 14, 2019), Toolmaker51 (Nov 15, 2018), volodar (Nov 16, 2018), will52100 (Nov 14, 2018)
    TM51 is right about eating a conventional dresser though. I tried to use my 7 spur wheel Ridged dresser on my wheel stack once make that twice first and last at the same time. it ate the rawls sown to a nub in no time.
  9. #7
    Dec 2013
    Florida
    rossbotics's Tools
    Holy Moly
    Doug
    Comments are always welcome
    Doug
  10. #8
    Nov 2018
    liberal's Tools
    This motor has 1.350 rpm.
  11. #9
    hemmjo's Tools
    Hey, you use what you have access to.
  12. The Following User Says Thank You to hemmjo For This Useful Post:
  13. #10
    VERY clever. This build hits on a lot of the factors we like:
    -washing machine motor
    -reuse of commonly discarded material
    -conglomeration (forming a grinding wheel from many cutting discs)
    My best guess is that compressing the discs like that would indeed reduce the risk of them exploding, as they love to do when run individually.
    Conceptually, this build reminds me of pauladan's hedge trimmer.
  14. The Following 2 Users Say Thank You to Jon For This Useful Post:
    liberal (Nov 15, 2018), Slim-123 (Nov 7, 2020)
