Results 1 to 10 of 12
Thread: Setup for grinding an ER32 collet chuck
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi,
    I put together the couple of last tools I posted here in an application video showing how I have reground a badly manufactured ER32 collet chuck :
    I tried to explain the rationale in the video subtitles, but the key points are :
    - It is a CM2 chuck, and my metal lathe spindle is CM3. So I decided to do it on my wood lathe, which has a really high quality spindle.
    Additional, I didn't want to use a CM3/CM2 adapter to put it in the metal lathe, it would introduce more run-out.
    Other reason, I try to avoid metal grinding as far as I can on my metal lathe. The wood lathe bed is less sensitive to the grit, a shot of compressed air and everything is clean.
    - I used an ER collet to setup precisely my 8° angle. To hold it in the spindle I chucked a ground 8mm bar in a good quality 8mm pull-back collet.
    - I needed a stone larger than the ER11 chuck of the HS spindle. The only one I had was this ball shaped white grinding bit. But it was not well centered so I started by trueing it up in the spindle, using a diamond tool
    - Obviously, with my setup, I miss the transversal slide, to take passes. As I show on the video, I have clamped on the bed two parallel cawls to keep the tool rest base perpendicular to the axis and thus avoiding to loose my angle setup. To take a pass, I just loosen the crank, and lightly tap with the plane hammer. It is low tech, but works pretty well.
    Finally, I am pretty happy with the result and again, this HS spindle is really the killer tool ;-)
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 16 Users Say Thank You to Christophe Mineau For This Useful Post:
    benkeller3 (May 6, 2020), Canyonman44 (May 6, 2020), Captn Roy (Jun 27, 2018), Carlos B (Jun 8, 2017), Carnel (May 7, 2020), emu roo (Oct 18, 2025), high-side (May 6, 2020), Hopefuldave (May 20, 2019), LMMasterMariner (Jun 7, 2017), Okapi (Feb 28, 2018), Paul Jones (Jun 12, 2017), PJs (Jun 27, 2018), rossbotics (Jun 8, 2017), Saltfever (May 6, 2020), Seedtick (Jun 7, 2017), Toolmaker51 (Jun 9, 2017)
    Thanks Christophe Mineau! We've added your Collet Chuck Grinding Setup to our Machining category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    Dec 2013
    Florida
    rossbotics's Tools
    Looks like it worked great, looks like that new high speed spindle worked out just fine for you, just goes to show you that there is more than one way to skin a cat
    Comments are always welcome
    Doug
  6. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    Christophe Mineau (Jun 8, 2017), emu roo (Oct 18, 2025)
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    I need to do that to my er32 x R8 collet chuck that is almost useless with its run out. I just make the tool post holder for some old HF grinder I did not use for anything else.
    1950 F1 street rod
    1949 F1 stock V8 flathead
    1948 F6 350 chevy/rest stock, no dump bed
    1953 chevy 3100 AD for 85 S10 frame going for a 4BT cummins motor, NV4500
    1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
    2000 National Sea Breeze 5th wheel trailer
    1998.5 Dodge 2500 4x4 Cummins,
  8. The Following User Says Thank You to Ed ke6bnl For This Useful Post:
    Quote Originally Posted by Christophe Mineau View Post
    I've noticed that myself too. Wood lathes can have great spindles, and HS spindle would be flawed from the get-go without. Good spindles share a common trait. That is dispersion, distance between bearings, in a proper housing.
    Christophe's done it again! I like the admission of low-tech, pointing out tech isn't always direct or efficient. It's best at filling cubicles. And advertising; don't know about anywhere else, here many ads love the word 'technology' in products. Evident tech was used in the overall process; but not resulting actual product. Hairspray or cosmetics? Nope, Chemistry. Men's multi-bladed shaver? Nope, Design. Cell Phone? Maybe, but not if Ergonomics or Interface fail.
    I regard use of the word itself as hype, just misspelled. Like "Kids, it's FUN"! rarely turned out so.
  10. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    Christophe Mineau (Jul 5, 2017), emu roo (Oct 18, 2025)
  11. #6
    Banned
    Jul 2017
    Hello,
    I'm researching to buy a 6-jaw chuck for my lathe, I read the article about wood lathe chucks and it says that I should buy a 3-jaw chuck instead of 6-jaw chuck. I've never used 3-jaw chuck before, can anybody confirm if a 3-jaw chuck is the best choice?
  12. The Following User Says Thank You to richardanmmol For This Useful Post:
  13. #7
    Article is wood lathes, are you running a metal working machine with wood? That's not uncommon at all. I turn PVC pipe often, which by the way machines nicely.
    A six jaw is rather like a collet, more completely 'encircling' a part, regardless the material. They cost more, mainly why they aren't more common, along with some aren't reversible or master style jaws. Jaws are a big consideration, and vary with what different people work on.
    At any rate 6 jaws distribute clamping pressure at least twice that of a 3 jaw; not more pressure, EVEN pressure. Imagine thin tube in a 3 jaw. Those 3 points of contact are separated by 120 degrees, enough tightening to grip and resist ejection can deform the tube past elasticity, that's a collapse.
    Better duck, here she comes.
  14. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  15. #8
    Adding to what Toolmaker 51 said about thin tube I don't have a 6 jaw and would still do this even if I had one for machining thin-wall tubing when ever possible I make a snug fitting plug to insert in the tube then when I chuck the tube in my lathe the plug will keep the tube from deforming allowing for much better clamping from the jaws.
    I got into the habit of doing this because I used to have a pipe profile cutting machine that had a 5 jaw chuck which had a range form 55 mm through 600 MM by reversing the jaws when cutting shapes in any 4 mm or thinner tubing with a diameter greater than 100 mm we made plugs for those tubes or cap welded the end being chucked since the machine reversed rotation abruptly while the plasma torch swung in wild arcs it could make up to a 3000 mm cut in less than a minute on 3 mm thick or less and when dealing with a 12 meter long 600 mm diameter tube only 2 or 3 mm thick you needed all of the positive clamping force you could get
    Using plugs on a metal late just seemed to be a good idea to implement especially for production work
  16. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Oct 18, 2025), Toolmaker51 (Jul 2, 2017)
  17. #9
    Adding to what Toolmaker 51 said about thin tube I don't have a 6 jaw and would still do this even if I had one for machining thin-wall tubing when ever possible I make a snug fitting plug to insert in the tube then when I chuck the tube in my lathe the plug will keep the tube from deforming allowing for much better clamping from the jaws...Using plugs on a metal late just seemed to be a good idea to implement especially for production work
    Another way are bushings, carefully bored to tube OD and split on one side, and cut some what on the other 180...
    As usual, click the pic. Setup for grinding an ER32 collet chuck-bushing.jpg
  18. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    emu roo (Oct 18, 2025), Paul Jones (Feb 28, 2018)
  19. #10
    Thank you, Christophe. Your information is very useful and instructive. I suspect I'm going to need to qualify the best spindle in my shop. I suspect it is in my old Jet milling machine. Mounting a suitable spindle grinder on the mill table with it's limited vertical space will be a challenge.
  20. The Following User Says Thank You to Ed Weldon For This Useful Post:
