[QUOTE=desbromilow;141650] At first I did not make the adjustable preload bar on the top beam and then there was a slight deflection problem. After adding the preload bar the deflection is no longer a problem. Mostly I need to bend materials with thicknesses of 0,8 - 1,2mm, occasionally 1,5mm. For thicker materials I have this small hydraulic bender but the max. width is only 160mm.
The angle bar is 100 x 100mm with a material thickness of 10mm. It is strengthened with a 80 x 8mm flat bar welded to the bottom of the top beam angle as you can see from one of the pictures.
The bed is made of a U-bar 60 x 140mm with an average material thickness of 8mm. The moving bending angle is 80 x 80mm with material thickness of 8mm. It is also strengthened with a 80 x 8mm flat bar.
