JR,
That is a pretty good looking kit PS, and definitely handy around the shop for
the price and a box to put it in. Be curious to see how the output looks on a scope with a single big cap but for $8. :cool: I was thinking of one of these
PWM dimmer controllers but they will need a wall wart to drive them. Most of the LED controllers are PWM that I have seen. This one could be taken out of the package and perhaps organized into your 4x4 box for $8, but again need 12VDC at 8A or less (~2A) if you are only driving a couple of 5-7W MR16s.
Personally for me and for shop use I prefer full on brightness and if it's too bright I just get a lower wattage units or a different color band because they are cheap. Also the goose neck allows me to move it away if it is too bright or causes dark shadows. That little track light I picked up was only about 18" long and was set up for 120VAC already...plug n' play and with 4-50W equivalent bulbs covered most of my lathe area from the ceiling. Nice that your unit had the stuff built in for 120VAC. I noticed the Target had a non-replaceable bulb...but I'm sure we could remedy that and replace with an
MR16 socket...dirt cheap by the bundle.
Whatever you do with lighting your space I'm sure it will be perfect for you and your fine little mill setup. :hattip: ~PJ
