Results 1 to 10 of 18
Thread: Shop Air Cleaner
    Supporting Member mr95gst's Avatar
    Apr 2014
    Murfreesboro, TN, USA
    mr95gst's Tools
    Shop Air Cleaner
    I have been working out of a 2 car garage recently and I have been increasingly concerned about the air quality. Every time I do any woodworking I can see a cloud of fine particles floating around the garage. I happened to come into possession of some damaged fans and decided to build an air cleaner. I modeled it after the Jet/Wen/Powertec air cleaners. I purchased the Powertec brand filters from Amazon for under $20. All the other materials were free.
    *****PHOTOBUCKET HIJACKED MY PICTURES SO I HAVE EDITED THE POST TO ADD THE PICTURES BACK. THEY ARE NO LONGER IN ORDER TO MATCH COMMENTARY MADE WHEN THE THREAD WAS STARTED.
    These are the fans I used. They are cooling fans designed to be mounted on the doors of industrial control panels. Each fan was rated at 300 cfm. The fan cages were damaged so they were thrown in the trash. The motors still worked so I grabbed them..
    I made some custom mounts out of oak scrap. Then I put them on a MDF frame.
    This is the box that houses the fans and filters. The main panels are 1/4" mdf and braced with pine.
    This is the 1 micron inner filter
    This is the 3 micron outer filter
    This is the air cleaner finished and mounted on the ceiling. The dimensions are 18"x11"x22" and it weights roughly 15 to 20 lbs. Right now I am controlling it will a simple on/off switch. I am think about changing it to a variable speed switch so that I can control the speed of the fans. Initially I was a bit worried that I wasn't going to get enough flow through the filters, but I was wrong. This thing is a beast. I am getting plenty of suction through the filters. I still need to make a front cover to diffuser the air coming out of the fans, but it is functional for the time being.
    Attached Thumbnails Attached Thumbnails Shop Air Cleaner-20170430_145419.jpg   Shop Air Cleaner-20170430_182908.jpg   Shop Air Cleaner-20170430_183217.jpg   Shop Air Cleaner-20170430_183556.jpg   Shop Air Cleaner-20170505_211819.jpg
    Shop Air Cleaner-20170505_211828.jpg   Shop Air Cleaner-20170505_211835.jpg   Shop Air Cleaner-20170505_212624.jpg   Shop Air Cleaner-20170505_212630.jpg   Shop Air Cleaner-20170505_214748.jpg
    Shop Air Cleaner-20170505_214807.jpg   Shop Air Cleaner-20170505_215108.jpg   Shop Air Cleaner-20170506_122943.jpg   Shop Air Cleaner-20170506_122953.jpg   Shop Air Cleaner-20170506_133048.jpg
  2. The Following 12 Users Say Thank You to mr95gst For This Useful Post:
    baja (Apr 29, 2020), blkadder (Feb 17, 2018), Carlos B (May 27, 2017), emu roo (Jul 28, 2025), llh49 (Apr 28, 2020), Marine2171 (Jun 17, 2018), Paul Jones (May 9, 2017), rlm98253 (May 9, 2017), Slim-123 (Apr 28, 2020), Tuomas (Jun 20, 2017), Vyacheslav.Nevolya (May 27, 2017), Wmrra13 (May 9, 2017)
    Supporting Member Wmrra13's Avatar
    Jan 2015
    Wmrra13's Tools
    Excellent work, many thanks for taking the time to document it!
    How loud is it?
    Are the filters cleanable or disposable? What PN?
  4. The Following User Says Thank You to Wmrra13 For This Useful Post:
    Supporting Member rlm98253's Avatar
    Excellent design and construction
  6. The Following User Says Thank You to rlm98253 For This Useful Post:
    Apr 2014
    mr95gst's Tools
    I am not sure the exact noise level. The fan manufacturer says they are 60db. I feel like it is a bit louder than that. It is definitely quieter than a vacuum but it is loud enough that it makes it hard to hear the TV I have against the wall. New, these fans are $300 a piece. They are crazy expensive and German made. I was lucky enough to dig them out of the trash for free!
    These are the Amazon links for the filters. The outer filter is disposable but the inner filter claims to be re-usable.
    https://www.amazon.com/POWERTEC-7500.../dp/B00O1N3INI
    https://www.amazon.com/POWERTEC-7500.../dp/B002DSA30O
  8. The Following 2 Users Say Thank You to mr95gst For This Useful Post:
    emu roo (Jul 28, 2025), Marine2171 (Jun 17, 2018)
    Jan 2015
    Wmrra13's Tools
    Great, thanks for the quick and detailed reply!
  10. The Following User Says Thank You to Wmrra13 For This Useful Post:
  11. #6
    Nov 2015
    this is wonderful!!!
  12. The Following User Says Thank You to mñm For This Useful Post:
  13. #7
    Thanks mr95gst! We've added your Shop Air Cleaner to our Dust Collectors category,
    as well as to your builder page: mr95gst's Homemade Tools. Your receipt:
  14. The Following User Says Thank You to DIYer For This Useful Post:
  15. #8
    All2skitzd's Avatar
    Dallas Texas
    All2skitzd's Tools
    That's badass, puts my ghetto fabu-cation to shame but wouldn't them bening in a shared chamber make the fans kinda fight each other decreasing efficiency and increasing motor heat? I was going to make one out of bounce house fan (from the trash) but that thing is louder then a vacuum and in the barn i live in there is only a limited amount of electricity and it took too much of it
  16. The Following 2 Users Say Thank You to All2skitzd For This Useful Post:
    emu roo (Jul 28, 2025), Wmrra13 (May 27, 2017)
  17. #9
    Supporting Member Carlos B's Avatar
    Canada
    Carlos B's Tools
    Nice build mr95gst.Looks great.
    From a popular rap: "If time is money then I need a loan."
    Carlos B,http://hobbyworkshopprojects.blogspot.com
  18. The Following User Says Thank You to Carlos B For This Useful Post:
  19. #10
    Jul 2016
    Nice Job! Do you think that a furnace squirrel cage blower would have the pressure to get the cfm thru the filters? I have scavenged several and the cfm is high and they are quiet. Thank you.
  20. The Following User Says Thank You to suther51 For This Useful Post:
