my shopmade tool cutter grinder attachment (part2) :
https://youtu.be/YhsSMiHo2jQ
greetings from Brazil
Celso Ari
Celso Ari
Thanks celsoari! We've added your Tool Grinding Setup to our Grinding category,
as well as to your builder page: celsoari's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-tool-grinding-setup"> <img src="/uploads/232057/homemade-tool-grinding-setup.png"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-tool-grinding-setup">Tool Grinding Setup</a> <span> by <a href="https://www.homemadetools.net/builder/celsoari">celsoari</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/grinding'>grinding</a>, <a href='https://www.homemadetools.net/tag/tool-post'>tool post</a>, <a href='https://www.homemadetools.net/tag/motor'>motor</a> </div> </div> </div> </div>
Thanks a lot for your second video.
I compared your customised mini bonelle with the mini-bonelle2, and yours looks nicely simplified, more easy to build, with my limited machining capabilities .. .. and skills.
I don't see how do you proceed in order to set the angles values (I don't see if you have made the graduated angle dials, or if you use an other way to set the angles) . Could you please explain that ?
Beautiful work!
-brino
