Thread: Silver soldering toolmakers clamps
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    Not the most interesting of tools but very useful when silver soldering components (or soft soldering, Welding etc.) that otherwise would be difficult to hold or setup.
    The two clamps are made from mild steel and are very simple to make. The clamp head can be rotated as well as being raised or lowered with simple cranked hand tight locks, into the desired position to hold the workpiece.
    The last component I used the clamps for was a top hat plunger which was quite small, the clamp made the process very simple.
    Using both clamps I have supported larger components to complete soldered joints.
    The photos will hopefully help the description:
    Silver soldering toolmakers clamps-soldering-clamps.jpgTwo clamps on hearth.
    Silver soldering toolmakers clamps-clamp-holding-job.jpgSingle clamp holding fluxed components to be silver soldered
    Silver soldering toolmakers clamps-soldered-job.jpgCompleted job
    Silver soldering toolmakers clamps-soldered-joint.jpgSolder joint
    Silver soldering toolmakers clamps-finished-componet.jpgTop hat plunger cleaned up and finished.
    Thank you for viewing
    The Home Engineer
  2. The Following 5 Users Say Thank You to thehomeengineer For This Useful Post:
    bruce.desertrat (Jun 15, 2024), johncg (Jun 15, 2024), Moby Duck (Jun 16, 2024), nova_robotics (Jun 17, 2024), Philip Davies (Jun 16, 2024)
    Thanks thehomeengineer! We've added your Silver Soldering Clamps to our Clamps category,
