Crank up the welder and make one of these.
https://www.youtube.com/watch?v=oaY74RtXxfI
Easy project.
Cheers Rob
Easy project.
Cheers Rob
Nice. Spreader bars are a must for lifting awkward, over length or difficult to balance loads safely
Best darn spreader I' ve seen...Cap
Technically this is actually a lifting beam, but everyone seems to call them spreader bars. They do spread the load lifting points.
A real spreader bar simply spreads a long length of chain with a length adjustable beam in beam arrangement.
However, a lifting beam has the advantage of taking up less vertical space under the crane jib.
Thanks xynudu! We've added your Load Spreader Bar to our Hoists category,
as well as to your builder page: xynudu's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-load-spreader-bar"> <img src="/uploads/211383/homemade-load-spreader-bar.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-load-spreader-bar">Load Spreader Bar</a> <span> by <a href="http://www.homemadetools.net/builder/xynudu">xynudu</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/hoist'>hoist</a>, <a href='http://www.homemadetools.net/tag/lifting'>lifting</a>, <a href='http://www.homemadetools.net/tag/spreader'>spreader</a> </div> </div> </div> </div>
