Results 1 to 10 of 11
Thread: Skirting board installation around an obstacle - GIF
Hybrid View
    May 2024
    Skirting board installation around an obstacle.
    Corner skirting molding - GIF
    emu roo (Aug 5, 2025), mr mikey (Aug 6, 2025)
    In my opinion it would have looked a lot better to mark off the center of where the pipe passed through then drilled a hole between the 2 pieces.
  4. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Aug 5, 2025), Floradawg (Aug 5, 2025), that_other_guy (Aug 10, 2025)
    Lake Tahoe
    IntheGroove's Tools
    Or, one piece with a hole in it. The tool required is called a "hole saw". Who knew...
  6. The Following User Says Thank You to IntheGroove For This Useful Post:
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    I think he should have kept slapping the two boards against the pipe as he started - eventually he would have indented the wood and smashed the pipe and it ouwl have been a perfect fit - just saying...
  8. The Following User Says Thank You to BuffaloJohn For This Useful Post:
    Frank S (Aug 5, 2025)
    Supporting Member Duke_of_URL's Avatar
    Aug 2018
    Texas
    That actually draws more attention to something you'd rather not be noticed. Seems to be another case of, "To a hammer everything looks like a nail."
  10. #6
    Mar 2018
    Hoosiersmoker's Tools
    Why not just make a hole slightly larger than the pipe, cut the trim through the center of the hole vertically then slide the two pieces together against the wall around the pipe. The two pieces should fit together with almost no seam since it was just one cut and no need to oversize the hole to accommodate the fitting. Perfect fit without all of the unnecessary cutting. If it was my house, I'd paint the pipe the trim color too.
    Also, why is there a water line coming through the wall as low as the trim? It just seems like an odd place to bring a water line through.
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
  11. #7
    Quote Originally Posted by Hoosiersmoker View Post
    Why why is there a water line coming through the wall as low as the trim? It just seems like an odd place to bring a water line through.
    Would most probably be Nat gas or propane.
  12. #8
    Mar 2018
    Looks like it's copper though.
    - Muhammad Ali
  13. #9
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Bad planning... or lazy...
  14. #10
    Lake Tahoe
    IntheGroove's Tools
    There could be another one a few feet away for a hydronic heat unit...
