Results 1 to 9 of 9
Thread: Slide hammer center punch
Hybrid View
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi Marv,
    One question, where do you put your hand ? No risk of having your fingers pinched with the sliding sleeve ?
    Good idea anyway.
    Thanks,
    Christophe
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    emu roo (Sep 10, 2025)
    Quote Originally Posted by Christophe Mineau View Post
    Hi Marv,
    Good idea anyway.
    Thanks,
    Christophe
    The second picture shows the hammer fully seated on the rod that holds the punch. Note that a section of the rod above the tip is still visible. The hammer section can't reach that area. That's where you put your fingers.
    Unlike my other slide hammer design...
    http://www.homemadetools.net/forum/s...7212#post36644
    on this one I usually do not drop the hammer and let it slide freely down the rod bearing the punch. Rather, while holding the rod as described above, I grasp the hammer with my other hand and use it to tap on the top of the rod.
    The fundamental idea behind both these tools is that the hammer is attached to the punch and, as a result, you don't lose registration while searching for and grasping the hammer.
  4. The Following User Says Thank You to mklotz For This Useful Post:
