Thread: Slide hammer power increasing trick - video
    Mentioned
    0 Post(s)
    Tagged
    5 Thread(s)
  2. The Following 7 Users Say Thank You to Jon For This Useful Post:
    baja (11-16-2019), high-side (11-17-2019), Midwestern640 (11-16-2019), Miloslav (11-16-2019), Rangi (11-16-2019), Scotty12 (11-16-2019), Seedtick (11-16-2019)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hemmjo's Tools
    That is a good trick, BUT after you remove the hub like that, make sure you replace the bearings or you will be back there again.
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Agreed. But usually the main reason for removing the hub is the bearings, but instead of using a slapjack hammer a puller with a center spindle bolt works better and not nearly so destructive on your body. Sometimes slid hammers are your only option I use mine quite frequently never tried wrapping a towel around it though to increase my force.
    Post your reply!
    Join 42,532 of us and get 200+ tool plans, tool eBooks, build guides, and much more.
    eBooks for Supporters
