Does anyone have any drawings or specification for a light duty - 3500#, low level 24", hydraulic scissor lift? I am a journeyman mechanic and a certified weld inspector so any drawings with welding symbols would be helpful.
Are you looking for something like the Omer scissor lift
Attachment 5573
Attachment 5574
Attachment 5575
if so and if I can locate the correct old hard drive where I have drawings stored I have built several models similar to those pictures
I designed and built lifts and elevators for close to 25 years
Frank
I need the scissor lift to work on the body pinch lifting rails of a Honda Civic or Accord. This would leave the tires free to able to remove or replace them. I would prefer a single hydraulic actuator in the middle of the two scissor lifting arms. All of the above lifts look like they could lift 10 tons.
Brian
Brian the aforementioned lifts are rated at around 3.5 to 4 tons they are an industrial usage lift that is true also they have a 50 to 72" rise height. They are considered light duty toys compared to many of the 4 and 6 column lifts I built with platforms measuring 11ft by 45ft with rise heights of 50+ feet and capacities over 30 tons.
but I think you may be looking for something along the lines of the scissor lifts offered by Harbor Freight for $1,500.00
these HF lifts are said to be rated at 6000 lbs however in practice raising anything much over 3500 will greatly shorten their use life. 2 small cylinders are used instead of 1 to further reduce the amount of steel required in the scissor arms
Attachment 5585
Attachment 5586
except you re looking for a much reduced overall raise going with a max rise height of 24 to 30 inches by using shorter cylinders and relocating the pivot moments on one of the HF lifts would make it a much safer more durable lift.
there is an Italian manufacture who does just this. I don't remember their name but the lift arms were made out of the equlivalent of ASTM gr70 3/4"x 3 1/2" flat steel If memory serves they sold for around 4000 Euros though.
Right - but as you suggest 1500.00 in the USA is 2000.00 in Canada. They had the above noted lift advertised at Princess Auto for 1995.00 two months ago, but once again it went way too high for my needs. I do not believe there is a light duty, 2 ton, 24" lift available, so I will just make my own. Thanks Frank.
...subscribed. I believe this may be the first potential tool build of this type we've seen. This could turn out to be very interesting. :)
Actually Brian there are some lifts being made and sold just like you are wanting
BendPac the people who bought Hydra-bend exhaust tubing bender design from me & a friend of mine 20 years ago. Manufacture a portable under-body jack called the ranger quick jack. However they do not ship to Canada.
Attachment 5598
Attachment 5599
Attachment 5600
Attachment 5601
I like this topic ,also. Attachment 5602 Picking up a car on pinch weld requires good rockers , will you be working on older cars ?
Thanks,Ed
I like this example. I will probably join the two scissors and use swing out plates to engage the lifting body pinch zones on Civics and Accords. I can also probably do without the electric over hydraulic drive and just use my manual pump. Thanks Frank
Thanks for the picture.
I don't want the drive on ramps. I will probably combine some of the ideas for this lift with the ones forwarded by Frank. The 4 lifting points on Honda's are 3 or 4 layers thick so they can take weight. I only specialize on 1996 to 2005 Honda and up here in Alberta we rarely use salt, so the under body parts are usually corrosion free for decades. I have a 1984 Winnie RV and there is not a speck of rust on it.
nixrox, please do a bunch of homework before you build anything.
Hydraulic systems can be very unsafe and fail at the worst times. As you probably know it's why when working under a car you don't use just a floor jack, you lift with it then use jack stands to make sure the car doesn't come down on you.
I only mention this so you'll be safe and so if you build a lift you'll include whatever is necessary to be extra safe.
The last thing any of us want is for something really bad to happen to you.
Hokiephd:
Thanks for your concern, but I have been working on all kinds of vehicles and aircraft for 50 years - with no accidents yet. I am also ex-military so safety was drilled into my head from day one. I believe that if a project cannot be done safely, then you just do not do it. I am also a quality assurance inspector, so I have witnessed more than my fair share of projects that did not work out very well. If anything, I will probably overbuild this lift just to make sure it does not fail. I will include a mechanical stop to remove the possibility of accidents due to hydraulic failure.
I want to thank those individuals who directed me to several different designs.
I believe I have enough information now to start fabricating my lift.
I'll send pictures when it is done.
Nixrox
Looking forward to those pics!
I'm curious about the seat you're going to use while working with the lift. Standard rolling seat? I ask because we've seen some interesting ideas here:
Motorcycle Maintenance Seat by dogmeatk -- Saab seat plus shopping cart base.
https://www.homemadetools.net/upload...ance-seat.jpeg
Ultimate Creeper by Mark -- More maneuverable version, with magnetic tool holder on armrest.
Attachment 5625
Hey, I like these roller seat ideas. I have a perfectly decent Civic seat in the car I was just going to take to the auto recyclers today. I currently have just a little round stool on 5 casters, with a tray underneath. I think the Civic seat is a much better option.
Thanks Jon.
