Thread: A small hole cutter for my Victor 2460 torch
Hybrid View
    Supporting Member oldtimer's Avatar
    Jan 2016
    oldtimer's Tools
    A while back I had a job cutting 30 close tolerance 3" holes in 12" I beam I tried using a guide ring but could not hold size. I came up with the idea of using a ball bearing with an inner lining to fit the tip and pressed the bearing in a machined outer housing. A 3/8 square bar was welded on the housing. A sliding pivot block fits the bar for cutting holes 2" to 6" It was small enough to work inside the I beam and I could cut the 3" holes with a -0 +1/32 tolerance. I made a spring steel bracket that clamps to the 1/2" gas tube. That made it easy to put on and take off.A small hole cutter for my Victor 2460 torch-victor-2460-snap-small-circle-cutter-001.jpg I think it is the handiest tool in my torch box.
  2. The Following 3 Users Say Thank You to oldtimer For This Useful Post:
    Jon (Jan 24, 2016), kbalch (Jan 25, 2016), PJs (Jan 26, 2016)
    Thanks oldtimer! We've added your Hole Cutting Fixture to our Cutting Torches category, as well as to your builder page: oldtimer's Homemade Tools. Your receipt:
