1 Attachment(s)
Small motor generator (pulse motor generator) powered with solar panels
Attachment 23374
https://www.youtube.com/watch?v=tw70ypGjMSA
The presented pulse motor generator generates Ac voltage. The input pulse current passes through a input coil iron less (bobbin) specifically positioned. The power wheel is composed of a fidget spinner with iron insertions and three neodymium magnet discs disposed N-N-N. The reed switch is positioned on the input coil The pulse motor generator is powered with two small solar panels. The reed switch is actuated by bringing a magnet near it. Once the magnet is pulled away from the switch, the reed switch will go back to its original position.
Materials used to build pulse motor generator:
1.fidget spinner with iron insertions -- the flywheel
image description
2. three neodymium magnet discs
image description
3. two small solar panels -- power source
image description
Details :
Voltage: 5V
Power: 1.2W
Current: 240 mA
Material: Monocrystalline
Size: 110 x 69mm
4. Step-up Module with adjustable booster power supply module
image description
AeroSemi MT3608 1.2MHz 2A Step Up Converter
2A maximum output current
2.0 to 24VDC input voltage range
28V maximum output voltage (trimpot adjustable)
93% peak efficiency (~200mA output current at 5Vin, 12Vout)
36 x 17 x 14mm
5. Coil iron less from a syncronous motor 230 V -- used to "capture" the magnetic flux gnerated by the pulse motorimage description
6.bobbin -- coil iron less used to produce a repulsive force
image description
7. reed switchimage description
8. led circuit
All the details : Motor generator, easy to replicate, powered with solar panels
