Small Rotary Mill/Drill Fixture
I built this little guy back in the mid-nineties to machine model car wheel centers. It simply clamped up in the cross-slide vise in the drill press and I would rotate it by hand to drill lug nut holes and make spokes in the wheel.
http://images59.fotki.com/v255/photo...MVC012S-vi.jpg
As you can see it has a bit of a patina problem. Taking it apart you can see it is pretty simple. A small 3" chuck (Sherline I believe) a 3/4" dia. spindle threaded for 3/4-16 on one end and a turned block with a bronze bushing pressed into it.
http://images56.fotki.com/v1298/phot...MVC011S-vi.jpg
This shows a wheel center I made. It is kind of rough in the lug nut areas and is a reject piece. I made this table to solve the roughness issue. Never had a problem holding the pieces with this.
http://images34.fotki.com/v1633/phot...MVC013S-vi.jpg
This was used in the drill press and, now that I have the FrankenMill, I decided to fix it up a bit and do some of the stuff that I couldn't when I didn't have the tools. The first thing I did was mill off a couple of flat spots so it will clamp square and sturdy into the mill vise.
http://images58.fotki.com/v279/photo...MVC014S-vi.jpg
Continued in next post
