Results 1 to 10 of 18
Thread: Socket wrench for toilet oval water shutoff valve
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    Imagine a 1/8" steel plate with an array of holes drilled through it. The back side of this plate has a chunk of 3/8" hex steel welded in the middle.
    In use bolts would be passed through the holes in a pattern that trapped the OSH. The bolts would be secured in place with nuts. Then a socket wrench would be used on the 3/8" hex steel to torque the OSH.
    If'n one used 3/16" or 1/4" plate and threaded the holes, nuts wouldn't be needed.
  2. The Following User Says Thank You to katy For This Useful Post:
    emu roo (Oct 9, 2025)
