Results 1 to 5 of 5
Thread: spade drill extension as a tap extension
    if you have ever had to tap a thread in a hole that was difficult to get to you might appreciate this
    I needed to tap some holes in a member that was 10 inches deep inside of a structure. Fortunately they were 1/4-20 so my spade drill extension worked perfectly. the square of the tap fit in the 1/4" bore and was secured in place by the grub screws the chuck end had 3 flats which allowed me to tighten this into my T handle
    baja (Nov 24, 2022), bruce.desertrat (Nov 23, 2022), katy (Nov 28, 2022), mwmkravchenko (Nov 24, 2022)
    Perth Ontario Canada
    Desperation makes for ingenuity. I have a few of those. One of them is 5 feet long!
    Thanks Frank S! We've added your Tap Extension to our Tapping and Threading category,
    Aug 2012
    Australia
    desbromilow's Tools
    Quote Originally Posted by mwmkravchenko View Post
    did you make the extension, modify a commercial one, or buy it? I have a couple I've picked up over the years, and plan to make a few around the 2-4 foot range
    Quote Originally Posted by desbromilow View Post
    Last time I got lucky Home Despot was dumping a 5 foot Klein bit extender. Now after I bought it I found out that Klein makes the hex not quite 1/4" my guess is that it is 6mm so you have to use their bits. But I made a 1 inch spade bit fit. Leatherman to the rescue. For about 20 years I have been using Bosh and now Freud spade bits that have a screw on the tip. Nearly as good as a true ships auger for drilling and very easy to sharpen.
    Mark
  7. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    desbromilow (Nov 29, 2022)
