Results 1 to 10 of 16
Thread: Spiling sticks, joggle sticks and a “digital” rule
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    There is a technique called “spiling”, which is a way of scribing a template to fit an awkward shape, mainly a boat-builder’s technique, but useful for fitting window boards, flooring, etc. The stick is usually a bit of lath, with some notches cut in it, eg
    Spiling sticks, joggle sticks and a “digital” rule-aa7cb77b-455b-479a-9382-d26ff56525f8.jpeg
    Suppose, for example, I wanted to cut a board which would fit around this old bit of spade (which is actually a forged plate by an established international artist Blacksmith, price on application.)
    Spiling sticks, joggle sticks and a “digital” rule-6f60ec5b-9fa4-476b-8374-97a8e3a6090d.jpeg
    I would cut a piece of paper or ply roughly to fit, place the point of the spiling stick around the perimeter, draw round the stick and do this as many times as necessary to record the data. Then I would lay the paper on the board, repeat the process of laying the stick on its silhouettes, but just mark the points. Then I would join up the dots and cut the board; (then there would be a lot of fiddle-faddle because the cuts weren’t quite right)
    Now, if there are any boat-builders, please tell me if they have a permanent spiling stick, because I have always thrown it away when finished.
    But I thought I would make a nice one today.
    Spiling sticks, joggle sticks and a “digital” rule-1795888b-2c0f-4a80-9162-b55f6a9f769e.jpeg
    (My daughter thinks the rough one is nicer)
    I have been intrigued by a tool which was probably used for the same purpose, but was at the same time a rule and effectively a depth gauge, in medieval times.
    The next two pictures are taken from an article in “The Mortice and Tenon”, no 3, the Carpenters’ Fellowship journal. The author, Henry Russell, who describes an exhibit in the Mary Rose exhibition. It is labelled “joggle stick”.
    Spiling sticks, joggle sticks and a “digital” rule-de72409a-82eb-45b5-a6d7-d65e6518ecde.jpegSpiling sticks, joggle sticks and a “digital” rule-6947f17f-c66c-4c91-92b8-1c846a94017a.jpeg
    The second picture is a reproduction of Medieval German carpenters hewing (the one on the left is using a mortising axe), but the one in the foreground evidently carries one in his belt.
    Now it took my fancy to make a joggle stick.
    Spiling sticks, joggle sticks and a “digital” rule-56e72c47-2b4a-458f-8b0a-4ce2a443d128.jpeg
    The notches are at 3/4” intervals.
    “ Digit” is a noun and “digital” an adjective, so, since a digit is 3/4”, I am calling it a DIGITAL RULE!
    Initially, I set it out on a graph in an old exercise book which belonged to my father. This is blocked at 5/8”, each block divided into 10 (1/16”). I have never come across this anywhere else.
  2. The Following 4 Users Say Thank You to Philip Davies For This Useful Post:
    cmarlow (Dec 21, 2021), Jon (Dec 22, 2021), nova_robotics (Dec 26, 2021), Sleykin (Dec 26, 2021)
    Isambard's Avatar
    Aug 2019
    Hawke's Bay, New Zealand
    Vinyl layers use a similar technique, although ones I seen and used myself, are just a small rectangular block, running a line off the opposite to the edge.
    Then use the same block to transpose back onto the vinyl...
  4. The Following User Says Thank You to Isambard For This Useful Post:
    Philip Davies (Dec 22, 2021)
    Thanks Philip Davies! We've added your Spiling Stick to our Measuring and Marking category,
    Feb 2019
    clavius's Tools
    It's interesting to me how all of these very specific tools and techniques develop for different trades going back hundreds of years. I had never heard of a spiling or joggle stick before now. I have also used the version that Isambard mentions (also while cutting vinyl flooring), though that will only resolve contours larger than the length of the block. Very useful in that application following along baseboards and such.
    I guess the "modern" and higher resolution version of the spiling stick is embodied in contour gauges like this:
    Essentially a sort of analog computer, so not quite into the digital age like yours Phillip. Cool info, and a very interesting way to solve a problem.
  7. The Following 2 Users Say Thank You to clavius For This Useful Post:
    carloski (Dec 26, 2021), Philip Davies (Dec 22, 2021)
    Apr 2021
    Thanks Phillip. It’s good when very old technology does the job. I can’t think of a modern equivalent that will do the same thing. I’ve heard of (and used) a ‘ticking’ stick before. Very similar but less elaborate in the shape of it. I wonder if they’re the same thing by different names or subtly different? Any ideas?
  9. The Following User Says Thank You to andrew mcgregor For This Useful Post:
  10. #6
    Dec 2015
    Reading, Berks, UK
    Quote Originally Posted by andrew mcgregor View Post
    Thanks, Andrew. I had forgotten that it was also called a ticking stick. Whatever the name, the scribing technique is the same, but personally I think that the notches were used for measurement, which is why they were kept in a. sheath. My “digital rule”, being tapered, could be used, with dividers, to measure intervals of 1/32” across the width. But it’s entirely conjectural.
  11. #7
    What I gather [pix of textbook not legible] and a particular contour/ notch pattern not a requirement; it seems to me a pointy version of a French Curve template. With enough such templates, allows any [nearly] set of points to form a curve........often with frustrating amount of trial and error.
    The notches are unique in contour, so positioning is more accurate and distinct than a straight taper. Follows that picking up angular orientation better than a scale could, with need to record many deviations from an abstract datum. Main thing, the point represents actual contour, compared to "kerf" created by tracing a pencil tip.
    Think that's what I thought while writing. Only one thing is sure; never seen or heard the like of, in any of it's names! So I'm googling it; one serious rabbit hole.
  12. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Philip Davies (Dec 23, 2021)
  13. #8
    Dec 2015
    Reading, Berks, UK
    Thanks, I am glad you were intrigued. If you wish, I’ll have another attempt at reproducing the text.
  14. #9
    Yes Phillip, the 2nd greatest aspect here (HMT.net); that exposure to completely foreign, or forgotten, or plain ol' just not passed down techniques. Perfect example; while web has plenty about spiling, likely we'd never cross it, save a bout of grievous misspelling.
    And to answer what is *1, that's easy. Facets! The astounding group of individuals, sharing interests without requirement of like-mindedness.
    Occurs what makes this favored by boatwrights. We normal machinists and engineers might work in 3 planes, but those are relatively simple, even with compound angles and such. Boats have very little even just perpendicular, parallel or flat!
  15. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    Christophe Mineau (Dec 25, 2021), Philip Davies (Dec 24, 2021)
  16. #10
    Dec 2015
    Reading, Berks, UK
    Spiling sticks, joggle sticks and a “digital” rule-55f20093-2c8b-4096-b7f9-7e70df54f1ce.jpeg
    Hope these are legible
    Attached Thumbnails Attached Thumbnails Spiling sticks, joggle sticks and a “digital” rule-c93ce10c-787e-499c-bcda-6a5018258ac6.jpeg   Spiling sticks, joggle sticks and a “digital” rule-image.jpg
  17. The Following 2 Users Say Thank You to Philip Davies For This Useful Post:
    Inner (Dec 27, 2021), Toolmaker51 (Dec 24, 2021)
