Two video's the follow up video is an improvement on the first video about improvements.
https://www.youtube.com/watch?v=ywf7qZynp3Y
Original post
https://www.youtube.com/watch?v=FDoL_K4IZQQ
Original post
Thank you for the informative update. I've been looking at these and was wondering if the concentricity is maintained after loading? What happens if you push on the spindle to simulate cutting forces and then release the pressure. Is the runout still good?
I still have less r/o than before adding grease to the barrel even when applying pressure to the spindle.
Thanks mr_modify1! We've added your Spindex Accuracy Fix to our Measuring and Marking category,
as well as to your builder page: mr_modify1's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-spindex-accuracy-fix"> <img src="/uploads/252706/homemade-spindex-accuracy-fix.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-spindex-accuracy-fix">Spindex Accuracy Fix</a> <span> by <a href="https://www.homemadetools.net/builder/mr_modify1">mr_modify1</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/modification'>modification</a>, <a href='https://www.homemadetools.net/tag/indexing-unit'>indexing unit</a> </div> </div> </div> </div>
That's great. Thank you for the reply. Happy new year!
