Results 1 to 4 of 4
Thread: spinning tools
    Berkshire UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thehomeengineer's Tools
    spinning tools
    Hi All
    This is a tool i use when spinning on my Colchester Student lathe. The photo below shows the external tool, when it comes in contact with the material the steel diameter rotates as it is on bearings as you force the sheet material over the former.
    This is the tool I use on internal diameters
    The photos below show the former's I had to make to produce the differential brass covers. The first thing was to cut the material into a washer shape and anneal. The material then has the internal diameter pressed on the hydraulic press to deform the material with two passes so the material doesn't crack (two different diameters on the press tool) annealing after each pressing. The die is then transferred to the lathe and the work piece is then trapped between the two former's (pressure turning)Basic setup and method for pressure turning in the lathe. The external spinning tool is then forced into the material to flow over the former while the lathe is rotating at about 400 RPM. (several times being removed and annealed to prevent cracking) Once over the former both the internal and external lengths are trimmed (part off to desired lengths) The internal diameter dimension is first trimmed as a jubilee clip holds the work piece to former. and then pressure turn so the external can be cut.
    The former's are rusty as this job was done several years ago and they have just been under the bench.
    spinning tools-press-tool.jpg spinning tools-die-piunch.jpg spinning tools-dies-2nd-op.jpg spinning tools-dies.jpg
    The photo below shows one side of the diff with the completed brass cover in place.
    The photo below shows another spinning I made which is a 10" diameter cladding clamping ring
    Thank you for viewing
    The Home Engineer
  2. The Following 10 Users Say Thank You to thehomeengineer For This Useful Post:
    baja (10-25-2019), DIYer (10-23-2019), Jon (10-23-2019), KustomsbyKent (10-27-2019), Philip Davies (10-25-2019), rendoman (10-23-2019), rossbotics (10-24-2019), sossol (10-25-2019), Stevohdee (10-24-2019), volodar (10-26-2019)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks thehomeengineer! We've added your Spinning Tool to our Metalworking category,
    May 2013
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    it would nice to see you spin something.
    Berkshire UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unfortunately I have quite a few projects on the go at the moment but haven’t had a need to do any spinning but when the opportunity arises I will do a video and post on HMT
    Post your reply!
    Join 42,532 of us and get 100+ tool plans, tool eBooks, build guides, and much more.
    59 Best Homemade VisesTube Bender Build Guide
  6. The Following User Says Thank You to thehomeengineer For This Useful Post:
