Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 35
Thread: Split Point Drill sharpening
    Supporting Member bobneumann's Avatar
    Jul 2018
    bobneumann's Tools
    Inexpensive and effective approach for sharpening and split-pointing drillbits
  2. The Following 21 Users Say Thank You to bobneumann For This Useful Post:
    asterix (Aug 28, 2025), Carnel (Aug 9, 2022), emu roo (Nov 22, 2024), JDrouin (Apr 28, 2020), jimfols (Jan 8, 2019), kboy0076 (Sep 13, 2022), Ken Koch (Apr 2, 2019), Kevic (Jan 7, 2019), olderdan (Jan 10, 2019), oldpastit (Jan 14, 2019), Paul Jones (Jan 17, 2019), Priemsy (Jan 13, 2019), Ralphxyz (Aug 28, 2025), ranald (Jan 7, 2019), rendoman (Jan 10, 2019), Scotsman Hosie (May 14, 2019), Seedtick (Jan 7, 2019), tonyfoale (Jan 14, 2019), Toolmaker51 (Jan 9, 2019), uv8452 (Aug 8, 2022), walgui (Jan 19, 2019)
    Mar 2013
    Switzerland
    Okapi's Tools
    Hello Bob,
    This is what we call now a diamond point, on this video I'm not in accordance with the use of the wheel freehand, it's dangerous if it broke and that can comes easily.
    When I was an apprentice we learn to cut the rear angle on the same grinding tool we use normally and with the protections included, now it's no more authorized to learn that to apprentices because people have the bad attitude to take protections out, but when made correctly it's without danger.
  4. The Following User Says Thank You to Okapi For This Useful Post:
    emu roo (Aug 28, 2025)
    Jul 2018
    bobneumann's Tools
    First of all, thanks for watching and for your honest feedback.
    Quote Originally Posted by Okapi View Post
    Hello Bob,
    I'm not sure that I agree with that. Eye protection is a must, of course. But this cutoff wheel only weighs maybe 20 or 30 grams. So if it breaks, while it could definitely mess up an eye, it's pretty much harmless to the rest of my body, at least as far as permanent damage goes. I don't count a little scratch on my hands or arms as "danger".
    I also have pneumatic and electric cutoff tools. A full size cutoff wheel is much larger and has a lot more mass. Those I could consider dangerous to use in this fashion. (Even though I still do it, I admit that I'm doing something dangerous. ) But these little tiny dremel cutoff wheels just aren't dangerous, outside of eye protection.
  6. The Following 2 Users Say Thank You to bobneumann For This Useful Post:
    emu roo (Aug 28, 2025), tonyfoale (Nov 22, 2024)
    Mar 2013
    Switzerland
    Okapi's Tools
    Make the speed calculation, at 20'000rpm, what is the energy in Joules of 30 grams, it's a nice small bullet, I'm not in accordance to say it's not dangerous, and if you simply touch a finger at this speed can make some damages too(I had a problem with my 90'000rpm dentistry tool with a diamond head less than 1 gram which broke and need chirugical action to take it out of my arm…).
  8. The Following 4 Users Say Thank You to Okapi For This Useful Post:
    emu roo (Aug 28, 2025), PJs (Jan 9, 2019), Scotsman Hosie (May 14, 2019), Toolmaker51 (Jan 9, 2019)
    Thanks bobneumann! We've added your Split Point Drill Bit Sharpening Method to our Sharpening category,
    as well as to your builder page: bobneumann's Homemade Tools. Your receipt:
  10. #6
    Not siding with any parties; but it is accurate to see both are correct. All tools carry that instant of failure, whether it occurs or not. I'm no safety-fascist, few events are are manageable afterward. But others can be minimized with certain protective measures.
    I'd think mini tool wheels good point splitters; but with a simple V-block for the bit and yoke for motor. Split points have to be centered to penetrate where intended.
  11. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    Scotsman Hosie (May 14, 2019), uv8452 (Aug 8, 2022)
  12. #7
    There have been times when I have had to sharpen drill bits in the field using whatever grinding device I had at hand. My welding rig had a "V' trap on the back of the bed for welding small pipes or other things I usually would clamp the grinder in the "V" leaving both ads free for working the bit.
    I won't condemn nor condone double free hand I'm not the one who had to or chose to do it that way. I'll just say that I would not mostly due to the lack of absolute control over the grind angle I have split point / diamond point whatever you want to call it bits on a belt sander I actually prefer to sharpen my bits larger than 3/4" on my belt sander
  13. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Aug 28, 2025), Scotsman Hosie (May 14, 2019), Toolmaker51 (Jan 10, 2019)
  14. #8
    Living is dangerous, it always ends badly, whereas sharpening a drill bit freehand only ends badly in a small percentage of cases.
    Should we stop living or stop sharpening? I'll play the percentages.
  15. The Following 8 Users Say Thank You to tonyfoale For This Useful Post:
    123pugsy (Jan 19, 2019), aphilipmarcou (Jan 13, 2019), cognitdiss (Apr 27, 2024), emu roo (Aug 28, 2025), olderdan (Jan 10, 2019), Saltfever (Sep 15, 2022), Scotsman Hosie (May 14, 2019), Toolmaker51 (Jan 10, 2019)
  16. #9
    Living is dangerous, it always ends badly.
    Well that says it all really, is that an original observation as I have not heard it before but its a keeper.
  17. The Following User Says Thank You to olderdan For This Useful Post:
  18. #10
    Quote Originally Posted by olderdan View Post
    Alan,
    It was an original observation but I am sure that the same sentiments have been expressed by many others.
  19. The Following 5 Users Say Thank You to tonyfoale For This Useful Post:
    emu roo (Aug 28, 2025), olderdan (Jan 10, 2019), Paul Jones (Jan 17, 2019), Scotsman Hosie (May 14, 2019), Toolmaker51 (Jan 10, 2019)
