Squaring Up a Frame
This short article shows how to square up a frame in preparation for welding. The standard and accurate method is to measure the diagonals. By calculating the diagonals, you can avoid the “trial and error” bit.
http://rick.sparber.org/saf.pdf
Thanks Rick! I've added your Frame Squaring Method to our Measuring and Marking category, as well as to your builder page: Rick Sparber's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="/frame-squaring-method"><img src="/uploads/87052/frame-squaring-method.jpeg" alt="Frame Squaring Method" /></a> </div>
</div>
<div class="title">
<a href="/frame-squaring-method">Frame Squaring Method</a> <span> by <a href="/builder/Rick+Sparber">Rick Sparber</a></span> </div>
<div class="tags">
tags:
<a href="/tag/square">square</a>, <a href="/tag/frame">frame</a> </div>
</div>
</div>
</div>
