I built this dedicated Squarness Comparator (squarness checker) to take the place of a surface gage that I normally would convert over to a squarness comparator for checking something after grinding, having a tool that is made for a certain application speeds up the machining process, no more fumbling around with a surface gage a hand full of yokes and a dial indicator, this tool is dedicated for this purpose and will never be altered.
This tool will check the squarness of something from 1 ˝” to 6” in height, the same height as my cylinder square, for those of you that don’t know what a cylinder square is, it is one of the masters of squares.
The Comparator has a 7/8” thick cast iron base, a 7/8” round TG&P 303 Stainless steel column, an aluminum yoke with a brass thumb screw and a used but not abused .0005” graduated Federal dial indicator with .125”travel.
The base has been fine ground on the bottom (will be lapped later on) with a milled out pocket to reduce friction on the surface plate, there is also a machined radius (not hand ground) on the nose of the base for rotating to find the high point with the dial indicator, the column has a 3/8” hexagonal hole broached in the upper end for tightening, I have included multiple photos of the machining and grinding processes it took to manufacture this tool.
As always thanks for looking and happy machining.
Doug
Attachment 22887
Attachment 22888
Attachment 22889
Attachment 22890
Attachment 22891
Attachment 22892
Attachment 22893
Attachment 22894
Attachment 22895
Attachment 22896
Attachment 22897
