emu roo (May 26, 2026), Floradawg (May 26, 2026), nova_robotics (May 31, 2026)
Why? Because likely they have a volume problem and not a weight problem with shipping - they ship empty space with the tire hole...
Same reason why they compress hay bales of grass straw to ship overseas - it is a volume problem, not a weight problem - the shipping container has a fixed volume...
BuffaloJohn (May 28, 2026), Floradawg (May 28, 2026)
Too many indicators point to new tires; shop clean, tires clean, stickers on all, good tread,
all the same tread pattern, no road grime on the guys hands.
I searched for "nesting tires for shipping" That led me to you tube with a short version of the
same video with this explanation;
24,923 views Mar 21, 2026
VALUE ADDED: This method shows a simple way to reduce shipping space and
costs by stacking tires efficiently. It helps businesses and workers optimize
storage and transportation without extra equipment.
EDUCATIONAL VALUE: Nesting tires reduces volume by utilizing empty interior
space, a common logistics principle used in warehousing and shipping. This improves
load efficiency and lowers transportation costs.
HOW IT WORKS: The process involves inserting smaller or flexible tires into the hollow
center of a larger tire, creating a compact stack. By aligning the tires carefully and
compressing them slightly, multiple units can occupy the same footprint as a
single tire, maximizing available space during transport.
DESCRIPTION (SEO-Friendly): This video demonstrates an efficient tire nesting technique
used in logistics and shipping. By stacking multiple tires into one, workers can significantly
reduce storage space and improve transport efficiency. This practical method is widely used i
n warehouses, tire distribution centers, and supply chain operations to optimize load capacity.
EDUCATIONAL EXPLANATION: Tires are designed with hollow centers, which makes them ideal
for nesting. By leveraging this design, workers can minimize unused space in shipping containers
or trucks. This approach follows basic logistics optimization strategies, where maximizing volume
utilization leads to better cost efficiency and reduced environmental impact.
SPECIFICATIONS: The technique works best with flexible rubber tires of similar or compatible sizes.
It does not require specialized tools, only manual alignment and moderate pressure. Commonly applied
in bulk tire handling environments such as warehouses and distribution hubs.
